Hi Diogo, can you tell me what software you used and what model ? You manage to connect using the modbus port or the wired remote one ?
Hi Diogo nay chance that you can give me some tips about how you did it and the exact model you have ?
Hi Paulo, I didn’t receive any notifications so I was unable to reply. I was using my own code written in node.js to communicate over modbus TCP. The hardware is a PUSR module (look pusr.com) which has a mode in which it convert RTU to TCP and vice-versa.
Hi! Did any of you finally get it working? I have a domeo 210 FL 3V EU and would like to do the same. Thank you in advance!
Hi Diogo! Did you get it working? What model do you have? (I have DOMEO 210 FL 3V EU) I’d appreciate if you could share the code you used and some details about the process so that I can also try it out! I’d appreciate it a lot! Thank you in advance!
