I want to upgrade my rule which turns off my bathroom ventilation when the outdoor humidity is higher then the bathroom’s:
rule "Badkamer ventilatie"
Item gHumidityBadkamer changed
// 1. Check to see if the Rule has to run at all, if not exit.
if(gHumidityBadkamer.state == NULL ){
logWarn("Ventilation Function", gHumidityBadkamer.name.toString + gHumidityBadkamer.state.toString)
return;
// 2. If Humid is above 65% turn on Ventilation at highest setting
if(gHumidityBadkamer.state == UNDEF ){
VentilatieBadkamer.sendCommand(OFF)
} else if(gHumidityBadkamer.state <= 60 && VentilatieBadkamer.state == OFF) {
logInfo("Ventilation Function", "b1. Humidity Badkamer is " + gHumidityBadkamer.state.toString + " and " + "ventilation = " + VentilatieBadkamer.state.toString + ". No action needed.")
} else if(gHumidityBadkamer.state <= 60 && VentilatieBadkamer.state == ON) {
logInfo("Ventilation Function", "b2. Humidity Badkamer is " + gHumidityBadkamer.state.toString + " and " + "ventilation = " + VentilatieBadkamer.state.toString + ". Turning ventilation OFF.")
//} else if (gHumidityBadkamer.state >= 70 && VentilatieBadkamer.state != ON) {
} else if ((gHumidityBadkamer.state as Number) > (WeatherAndForecastCurrentHumidity.state as Number) && VentilatieBadkamer.state != ON) {
logInfo("Ventilation Function", "b3a. Humidity Badkamer is " + gHumidityBadkamer.state.toString + " and " + "ventilation = " + VentilatieBadkamer.state.toString + ". Turning ventilation ON.")
logInfo("Ventilation Function", "b3b. Humidity outside is " + WeatherAndForecastCurrentHumidity.state.toString)
VentilatieBadkamer.sendCommand(ON)
} else if (gHumidityBadkamer.state >= 65 && VentilatieBadkamer.state == ON && WeatherAndForecastCurrentHumidity.state >= 65) {
logInfo("Ventilation Function", "b4. Humidity Badkamer is " + gHumidityBadkamer.state.toString + " and " + "ventilation = " + VentilatieBadkamer.state.toString + " WeatherAndForecastCurrentHumidity is: " + WeatherAndForecastCurrentHumidity.state.toString + ". Turning ventilation OFF.")
This results in:
[INFO ] [me.model.script.Ventilation Function] - b3a. Humidity Badkamer is 82.12 and ventilation = OFF. Turning ventilation ON.
[INFO ] [me.model.script.Ventilation Function] - b3b. Humidity outside is 93 %
So it is saying 82.12 is greater then 93?
I’ve tried it without as Number
and on openHAB 2.4.0 and 2.5.0.M3.
