Unicode in Main UI and HabPanel broken after restart
I have observed the following behaviour and I wonder does OpenHab 3 have an issue with Unicode characters?
I have created a remote control for my TV in HabPanel and I uaed Unicode characters to label the buttons, e.g. :speaker_high_volume: ,:ok_button:,…
This has been working without a problem on OH 2.5
Now, after migration to OH3, I have noticed that after every restart of the openhab service, these icons are replaced by one or two question marks. I can switch to edit mode and replace them by the icons again and it will be fine until the next restart.
I checked if it is only HabPanel and added a :television: to the label of a cell in the new Main UI. This, too, does not survive a restart.
Is there a bug in how openhab persists the UI configuration? And if so, where would be the right place to open an issue about that?
I had a similar issue and had to set UTF 8 as described here https://community.openhab.org/t/oh3-umlaute-change-to-after-restart/111350/8 … not sure which system you are running on so this might not be aplicable.
Thank you for the link (again :slightly_smiling_face:). I am running on Raspbian 10. Not sure where to find the setting but I will read through your link and try my best…
Same as me, AFAIK it was
sudo dpkg-reconfigure locales
as the link I shared above describes …
EDIT: My settings
Screenshot 2021-02-08 at 22.03.29
Hope it works for you …
It was easy to find in the RaspberryPi Configuration dialog, I changed the setting to UTF 8 and now everything is fine. :+1:
Great to hear! :+1:
