Update 21/10 6h40 CET (see below for a previous post - I’m unable to post again, so I have to edit):
A reboot later, everything went back to what it was. No error on startup, except this:
2024-10-20 20:21:38.248 [WARN ] [.core.thing.binding.BaseThingHandler] - Handler UniFiProtectG5CameraThingHandler of thing unifiprotect:g5camera:f4b3b5f657:F4E2C676310A tried accessing its bridge although the handler was already disposed.
In the logs:
2024-10-20 22:21:56.341 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Request failed reason: EXECUTION_FAULT message: Execution fault when sending request to UniFi Protect
java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:732) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.request.UniFiProtectRequest.sendRequestGetResponse(UniFiProtectRequest.java:170) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.request.UniFiProtectRequest.sendRequest(UniFiProtectRequest.java:121) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.refreshBootstrap(UniFiProtectNvr.java:166) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.refreshProtect(UniFiProtectNvr.java:223) ~[?:?]
at org.openhab.binding.unifiprotect.internal.thing.UniFiProtectNvrThingHandler.refresh(UniFiProtectNvrThingHandler.java:206) ~[?:?]
at org.openhab.binding.unifiprotect.internal.thing.UniFiProtectNvrThingHandler.run(UniFiProtectNvrThingHandler.java:170) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
Caused by: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.onComplete(AuthenticationProtocolHandler.java:164) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:424) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:374) ~[?:?]
at org.eclipse.jetty.http.HttpParser.handleContentMessage(HttpParser.java:596) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseContent(HttpParser.java:1723) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1552) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:208) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:148) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
... 1 more
2024-10-20 22:21:56.350 [DEBUG] [al.model.request.UniFiProtectRequest] - Response is null, it shouldn't be
2024-10-20 22:21:56.350 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Credentials expired, logging in again
This repeats itself every 2 hours on the dot.
I checked the login credentials of the binding, they give access to everything on the Dream Router.
What happened 20/10 around 20h00 CET:
I eventually realized I do have a firewall rule preventing my devices from reaching out to other DNS servers than the two I created. I added the IP address of my camera to that rule (thus giving it the freedom to use whatever port it wants to the outside world), and now I get another error at startup:
19:33:30.369 [WARN ] [b.core.thing.binding.BaseThingHandler] - Handler UniFiProtectG5CameraThingHandler of thing unifiprotect:g5camera:f4b3b5f657:F4E2C676310A tried accessing its bridge although the handler was already disposed.
(This one was actually always there, but the next one is new)
19:34:31.928 [WARN ] [ommon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
java.lang.NullPointerException: Cannot invoke "org.openhab.binding.unifiprotect.internal.event.UniFiProtectEventManager.stop()" because "this.eventManager" is null
at org.openhab.binding.unifiprotect.internal.thing.UniFiProtectNvrThingHandler.refresh(UniFiProtectNvrThingHandler.java:208) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
In the logs, I see:
2024-10-20 19:33:30.318 [DEBUG] [al.model.request.UniFiProtectRequest] - >> POST https://192.168.1.1/api/auth/login
2024-10-20 19:33:30.323 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Request failed reason: EXECUTION_FAULT message: Execution fault when sending request to UniFi Protect
java.util.concurrent.ExecutionException: java.net.ConnectException: Verbinding is geweigerd
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[bundleFile:9.4.54.v20240208]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[bundleFile:9.4.54.v20240208]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:732) ~[bundleFile:9.4.54.v20240208]
at org.openhab.binding.unifiprotect.internal.model.request.UniFiProtectRequest.sendRequestGetResponse(UniFiProtectRequest.java:170) ~[bundleFile:?]
at org.openhab.binding.unifiprotect.internal.model.request.UniFiProtectRequest.sendRequest(UniFiProtectRequest.java:121) ~[bundleFile:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.login(UniFiProtectNvr.java:105) [bundleFile:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.start(UniFiProtectNvr.java:241) [bundleFile:?]
at org.openhab.binding.unifiprotect.internal.thing.UniFiProtectNvrThingHandler.initialize(UniFiProtectNvrThingHandler.java:105) [bundleFile:?]
at jdk.internal.reflect.GeneratedMethodAccessor41.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:569) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:147) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
Caused by: java.net.ConnectException: Verbinding is geweigerd
at sun.nio.ch.Net.pollConnect(Native Method) ~[?:?]
at sun.nio.ch.Net.pollConnectNow(Net.java:672) ~[?:?]
at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:946) ~[?:?]
at org.eclipse.jetty.io.SelectorManager.doFinishConnect(SelectorManager.java:355) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector.processConnect(ManagedSelector.java:347) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector.access$1700(ManagedSelector.java:65) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.processSelected(ManagedSelector.java:676) ~[?:?]
at org.eclipse.jetty.io.ManagedSelector$SelectorProducer.produce(ManagedSelector.java:535) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produceTask(EatWhatYouKill.java:362) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:186) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:137) ~[?:?]
... 1 more
2024-10-20 19:33:30.341 [DEBUG] [al.thing.UniFiProtectNvrThingHandler] - Scheduling refresh job every 60s
2024-10-20 19:33:30.343 [ERROR] [al.thing.UniFiProtectNvrThingHandler] - UniFiProtect Offline due to failuer: Execution fault when sending request to UniFi Protect
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.login(UniFiProtectNvr.java:105) ~[bundleFile:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.start(UniFiProtectNvr.java:241) ~[bundleFile:?]
... 1 more
2024-10-20 19:33:30.379 [DEBUG] [ing.UniFiProtectG5CameraThingHandler] - Initializing G5 Camera name: Not initialized type: Not initialized
2024-10-20 19:33:31.049 [DEBUG] [al.thing.UniFiProtectNvrThingHandler] - Executing refresh job
2024-10-20 19:33:31.050 [DEBUG] [al.thing.UniFiProtectNvrThingHandler] - Refreshing Protect: 1163965694
2024-10-20 19:33:31.051 [DEBUG] [al.thing.UniFiProtectNvrThingHandler] - Refreshing the UniFi Protect Controller unifiprotect:nvr:f4b3b5f657
2024-10-20 19:33:31.054 [DEBUG] [al.model.request.UniFiProtectRequest] - Set json Body: {"remember":false,"password":"vuayc-9gomsAWeN@ByQc","rememberMe":false,"strict":false,"username":"openhab","token":null}
2024-10-20 19:33:31.054 [DEBUG] [al.model.request.UniFiProtectRequest] - Created new request host: 192.168.1.1, scheme: https, path: /api/auth/login
2024-10-20 19:33:31.054 [DEBUG] [al.model.request.UniFiProtectRequest] - New request: HttpRequest[POST /api/auth/login HTTP/1.1]@62df7936
2024-10-20 19:33:31.054 [DEBUG] [al.model.request.UniFiProtectRequest] - >> POST https://192.168.1.1/api/auth/login
2024-10-20 19:33:31.056 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Request failed reason: EXECUTION_FAULT message: Execution fault when sending request to UniFi Protect
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.login(UniFiProtectNvr.java:105) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.refreshProtect(UniFiProtectNvr.java:214) ~[?:?]
... 1 more
2024-10-20 19:33:31.058 [ERROR] [otect.internal.model.UniFiProtectNvr] - Failed to updated Cameras since we can't seem to login status: EXECUTION_FAULT
2024-10-20 19:33:31.059 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Status message: Execution fault when sending request to UniFi Protect exception: java.util.concurrent.ExecutionException: java.net.ConnectException: Verbinding is geweigerd
2024-10-20 19:34:31.059 [DEBUG] [al.thing.UniFiProtectNvrThingHandler] - Executing refresh job
2024-10-20 19:34:31.059 [DEBUG] [al.thing.UniFiProtectNvrThingHandler] - Refreshing Protect: 1163965694
2024-10-20 19:34:31.059 [DEBUG] [al.thing.UniFiProtectNvrThingHandler] - Refreshing the UniFi Protect Controller unifiprotect:nvr:f4b3b5f657
2024-10-20 19:34:31.060 [DEBUG] [al.model.request.UniFiProtectRequest] - Set json Body: {"remember":false,"password":"vuayc-9gomsAWeN@ByQc","rememberMe":false,"strict":false,"username":"openhab","token":null}
2024-10-20 19:34:31.060 [DEBUG] [al.model.request.UniFiProtectRequest] - Created new request host: 192.168.1.1, scheme: https, path: /api/auth/login
2024-10-20 19:34:31.060 [DEBUG] [al.model.request.UniFiProtectRequest] - New request: HttpRequest[POST /api/auth/login HTTP/1.1]@13f7b69f
2024-10-20 19:34:31.061 [DEBUG] [al.model.request.UniFiProtectRequest] - >> POST https://192.168.1.1/api/auth/login
2024-10-20 19:34:31.911 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Successfullt sent request
2024-10-20 19:34:31.913 [DEBUG] [al.model.request.UniFiProtectRequest] - Key: x-csrf-token, value: 74e190ff-59de-43fd-847c-ca66d2ce3880
2024-10-20 19:34:31.914 [DEBUG] [al.model.request.UniFiProtectRequest] - Created new request host: 192.168.1.1, scheme: https, path: /proxy/protect/api/bootstrap
2024-10-20 19:34:31.914 [DEBUG] [al.model.request.UniFiProtectRequest] - New request: HttpRequest[GET /proxy/protect/api/bootstrap HTTP/1.1]@5a0e7fb0
2024-10-20 19:34:31.914 [DEBUG] [al.model.request.UniFiProtectRequest] - >> GET https://192.168.1.1/proxy/protect/api/bootstrap
2024-10-20 19:34:31.918 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Successfullt sent request
2024-10-20 19:34:31.918 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Request is ok, parsing cameras
2024-10-20 19:34:31.919 [ERROR] [al.model.json.UniFiProtectJsonParser] - Failed to parse bootstrap json
2024-10-20 19:34:31.919 [DEBUG] [al.model.json.UniFiProtectJsonParser] - Failed to parse bootstrap json: <!doctype html><html lang="en"><head><meta charset="utf-8"><link rel="icon" href="/favicon.ico?v3" sizes="any"><link rel="icon" href="/favicon.svg?v3" type="image/svg+xml"><link rel="apple-touch-icon" href="/apple-touch-icon.png?v3"><title>UniFi OS</title><meta name="viewport" content="width=device-width,initial-scale=1"><script>window.UNIFI_OS_MANIFEST = {"model":{"id":"UDR","shortName":"UDR","longName":"UniFi Dream Router"},"images":[{"size":1024,"url":"/assets/images/1024.png?udr-3.0.0"},{"size":64,"url":"/assets/images/64.png?udr-3.0.0"},{"size":48,"url":"/assets/images/48.png?udr-3.0.0"}]}</script><script defer="defer" src="/main.0178b959830932983dec.js"></script><link href="/main.6bc650de.css" rel="stylesheet"></head><body id="portal-body"><div id="portal-root"></div></body></html>
com.google.gson.JsonSyntaxException: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 12 path $
at com.google.gson.JsonParser.parseReader(JsonParser.java:76) ~[?:?]
at com.google.gson.JsonParser.parseString(JsonParser.java:51) ~[?:?]
at com.google.gson.JsonParser.parse(JsonParser.java:115) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.json.UniFiProtectJsonParser.parseJson(UniFiProtectJsonParser.java:78) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.json.UniFiProtectJsonParser.parseBootstrap(UniFiProtectJsonParser.java:68) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.refreshBootstrap(UniFiProtectNvr.java:117) ~[?:?]
at org.openhab.binding.unifiprotect.internal.model.UniFiProtectNvr.refreshBootstrap(UniFiProtectNvr.java:185) ~[?:?]
Caused by: com.google.gson.stream.MalformedJsonException: Use JsonReader.setLenient(true) to accept malformed JSON at line 1 column 12 path $
at com.google.gson.stream.JsonReader.syntaxError(JsonReader.java:1659) ~[?:?]
at com.google.gson.stream.JsonReader.checkLenient(JsonReader.java:1465) ~[?:?]
at com.google.gson.stream.JsonReader.doPeek(JsonReader.java:551) ~[?:?]
at com.google.gson.stream.JsonReader.peek(JsonReader.java:433) ~[?:?]
at com.google.gson.JsonParser.parseReader(JsonParser.java:71) ~[?:?]
... 15 more
2024-10-20 19:34:31.926 [DEBUG] [ifiprotect.internal.UniFiProtectUtil] - Wrote file: /var/lib/openhab/tmp/bootstrap11375889675583845955.json
2024-10-20 19:34:31.926 [DEBUG] [otect.internal.model.UniFiProtectNvr] - Wrote bootstrap to temp file: /var/lib/openhab/tmp/bootstrap11375889675583845955.json
The binding works again - for now. (I don’t really understand how that is possible with a ‘refused connection’, but who am I
