I recently uninstalled the telegram v1 action by editing it out of the action =
line in services/addons.cfg
This has stopped my serial and ZWave bundles, see below.
Why ? Is there any dependency I should be aware of ?
If no, shall I file a bug, and if so where (openhab-distro
FWIW, happened on 2.5 but I doubt that’s related to the OH version.
2019-12-16 14:06:43.172 [INFO ] [internal.service.FeaturesServiceImpl] - Removing features: openhab-action-telegram/[1.14.0,1.14.0]
2019-12-16 14:06:55.063 [INFO ] [internal.service.FeaturesServiceImpl] - Changes to perform:
2019-12-16 14:06:55.065 [INFO ] [internal.service.FeaturesServiceImpl] - Region: root
2019-12-16 14:06:55.066 [INFO ] [internal.service.FeaturesServiceImpl] - Bundles to uninstall:
2019-12-16 14:06:55.068 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.action.telegram/1.14.0
2019-12-16 14:06:55.080 [INFO ] [internal.service.FeaturesServiceImpl] - Stopping bundles:
2019-12-16 14:06:55.086 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.serial/2.5.0
2019-12-16 14:06:55.146 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.zwave/2.5.0
2019-12-16 14:07:00.726 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-12-16 14:07:06.055 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.action.telegram/1.14.0
2019-12-16 14:07:06.077 [DEBUG] [.telegram.internal.TelegramActivator] - Telegram action has been stopped.
2019-12-16 14:07:06.082 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0
2019-12-16 14:07:06.098 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial/2.5.0
2019-12-16 14:07:06.127 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx/2.5.0
2019-12-16 14:07:06.141 [INFO ] [internal.service.FeaturesServiceImpl] - Uninstalling bundles:
2019-12-16 14:07:06.142 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.action.telegram/1.14.0
2019-12-16 14:07:06.159 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 16, for automation bundle 'org.openhab.action.telegram'
2019-12-16 14:07:06.161 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 16, for automation bundle 'org.openhab.action.telegram'
2019-12-16 14:07:06.163 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 16, for automation bundle 'org.openhab.action.telegram'
2019-12-16 14:07:06.224 [INFO ] [internal.service.FeaturesServiceImpl] - Refreshing bundles:
2019-12-16 14:07:06.225 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.action.telegram/1.14.0 (Bundle will be uninstalled)
2019-12-16 14:07:06.226 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.binding.zwave/2.5.0 (Should be wired to: org.openhab.core.io.transport.
serial/2.5.0 (through [org.openhab.binding.zwave/2.5.0] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial)"))
2019-12-16 14:07:06.227 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.config.serial/2.5.0 (Should be wired to: org.openhab.core.io.trans
port.serial/2.5.0 (through [org.openhab.core.config.serial/2.5.0] osgi.wiring.package; filter:="(&(osgi.wiring.package=org.eclipse.smarthome.io.transport.serial
)(version>=2.5.0)(!(version>=3.0.0)))"))
2019-12-16 14:07:06.228 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial/2.5.0 (Should be wired to: org.openhab.core.io
.transport.serial/2.5.0 (through [org.openhab.core.io.transport.serial/2.5.0] osgi.wiring.package; filter:="(osgi.wiring.package=org.eclipse.smarthome.io.transp
ort.serial)"))
2019-12-16 14:07:06.229 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx/2.5.0 (Wired to org.openhab.core.io.trans
port.serial/2.5.0 which is being refreshed)
2019-12-16 14:07:06.230 [INFO ] [internal.service.FeaturesServiceImpl] - org.openhab.core.io.transport.serial.rxtx.rfc2217/2.5.0 (Wired to org.openhab.core.
io.transport.serial/2.5.0 which is being refreshed)
2019-12-16 14:07:06.840 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.binding.zwave'
2019-12-16 14:07:06.841 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.binding.zwave'
2019-12-16 14:07:06.841 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.binding.zwave'
2019-12-16 14:07:06.843 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.binding.zwave'
2019-12-16 14:07:06.899 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.serial'
2019-12-16 14:07:06.901 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.config.serial'
2019-12-16 14:07:06.901 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.serial'
2019-12-16 14:07:06.902 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.serial'
2019-12-16 14:07:06.909 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial'
2019-12-16 14:07:06.911 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.io.transport.serial'
2019-12-16 14:07:06.911 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial'
2019-12-16 14:07:06.912 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial'
2019-12-16 14:07:06.918 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial.rxtx'
2019-12-16 14:07:06.920 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.io.transport.serial.rxtx'
2019-12-16 14:07:06.920 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial.rxtx'
2019-12-16 14:07:06.922 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial.rxtx'
2019-12-16 14:07:06.930 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial.rxtx.rfc2217'
2019-12-16 14:07:06.932 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.io.transport.serial.rxtx.rfc2217'
2019-12-16 14:07:06.932 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial.rxtx.rfc2217'
2019-12-16 14:07:06.934 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.io.transport.serial.rxtx.rfc2217'
2019-12-16 14:07:07.410 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
