sptzdmnc
(Dominic Spatz)
May 6, 2023, 5:20pm
1
Hey, when trying to implement volkszähler (basically a smart meter integration for all kind of meters and gateways), I am experiencing some issues.
I wanted to use the MQTT implementation. This sends numbers, in case of the first channel, thats watt-hours (Wh) for the value “positive active energy” / OBIS 1.8.0:
So i will get kWh instead of Wh
Where or how can i specify, what unit (Wh, kW etc.) i want to use for a certain channel/item?
Thanks for your support!
You have to set the unit parameter.
Thing topic smartmeter "Smartmeter" @ "Basement"
Channels :
//1.8.0: Zählerstand Bezug
Type string : chn0_id "Chn 0 ID" [stateTopic="RPI/smartmeter/chn0/id"]
Type string : chn0_uuid "Chn 0 uuid" [stateTopic="RPI/smartmeter/chn0/uuid"]
Type number : chn0_timestamp "Chn 0 Update" [stateTopic="RPI/smartmeter/chn0/agg", transformationpattern="JSONPATH:$.timestamp" ]
Type number : chn0_reading "Chn 0 Reading" [stateTopic="RPI/smartmeter/chn0/agg", transformationpattern="JSONPATH:$.value", unit="Wh" ]
Channels :
//2.8.0: Zählerstand Lieferung
Type string : chn1_id "Chn 1 ID" [stateTopic="RPI/smartmeter/chn1/id"]
Type string : chn1_uuid "Chn 1 uuid" [stateTopic="RPI/smartmeter/chn1/uuid"]
Type number : chn1_timestamp "Chn 1 Update" [stateTopic="RPI/smartmeter/chn1/agg", transformationpattern="JSONPATH:$.timestamp" ]
Type number : chn1_reading "Chn 1 Reading" [stateTopic="RPI/smartmeter/chn1/agg", transformationpattern="JSONPATH:$.value", unit="Wh" ]
Channels :
//16.7.0: Leistung (momentan)
Type string : chn2_id "Chn 2 ID" [stateTopic="RPI/smartmeter/chn2/id"]
Type string : chn2_uuid "Chn 2 uuid" [stateTopic="RPI/smartmeter/chn2/uuid"]
Type number : chn2_timestamp "Chn 2 Update" [stateTopic="RPI/smartmeter/chn2/agg", transformationpattern="JSONPATH:$.timestamp" ]
Type number : chn2_reading "Chn 2 Reading" [stateTopic="RPI/smartmeter/chn2/agg", transformationpattern="JSONPATH:$.value", unit="W" ]
