I hereby present you my universal toggle widget. The widget can be used in three different ways:
- Toggle a single switch
- Toggle a number of similar switches (e.g. some light switches)
- Toggle a number of similar switches (like 2.) together with a main switch to toggle all switches at the same time
Note that the widget does not care what switches you give it when you are using it in mode 3. The way I described it is just the way I am using it/the way it is meant to be used.
This is what it looks like:
And in action:
Configuration:
Title: Card title (leave empty for no title bar)
Footer: Card footer (leave empty for no footer) NOTE: There appears to be a bug that sometimes prevents the scrolling of the grouptoggle swiper slide that I filed here: oh-repeater does not work correctly to populate f7-swiper-slides in f7-swiper · Issue #840 · openhab/openhab-webui · GitHub Setting a card footer with an expression (as in the example) seems to “fix” this but unfortunately not reliably. Please let me know if this is also an issue for you or if you know how to fix it.
F7 Icon: The name of the icon that should be shown in the widget
Color: The color scheme to use for the widget
Main toggle item: The “main switch” for the group or just a single switch if no group is configured (leave empty if you only want to switch a group of items without main switch)
Group toggle array: The array of switches that should be shown on the second slide or the single slide if the Main toggle item is omitted. Syntax: “<Label shown above icon of item 1>”,"<Name of item 1>"|"<Label shown above icon of item 2>","<Name of item 2>", repeat as needed (leave empty if you only need the main switch)
Resources
The Code:
uid: universal_toggle_v3
tags: []
props:
parameters:
- description: Title of the card
label: Title
required: false
type: TEXT
- description: The card footer
label: Footer
required: false
type: TEXT
- description: Name of the Icon (see https://framework7.io/icons/ for available icons)
label: F7 Icon
required: true
type: TEXT
- description: Color scheme for icons and toggles (see https://framework7.io/docs/color-themes.html for available color schemes)
label: Color
required: true
type: TEXT
- context: item
description: Main toggle item (use for single toggle or as main switch for group)
label: Item
required: false
type: TEXT
- description: Group toggles (use as group with or without main toggle)
label: Group toggle Array
required: false
type: TEXT
parameterGroups: []
timestamp: Jan 26, 2021, 4:56:03 PM
component: f7-card
title: =(props.title)
slots:
default:
- component: f7-card-content
slots:
default:
- component: f7-swiper
init: true
pagination: "=(props.maintoggle) && (props.grouptogglearray) ? true : false"
params:
slidesPerView: 1
pagination:
clickable: true
style:
width: 100%
height: 175px
slots:
default:
- component: f7-swiper-slide
visible: "=(props.maintoggle) ? true : false"
style:
width: 100%
height: 100%
slots:
default:
- component: f7-col
class:
- display-flex
- flex-direction-column
- align-items-center
- justify-content-space-evenly
style:
width: 100%
height: 100%
slots:
default:
- component: f7-icon
f7: =props.icon
size: '=(props.grouptogglearray) ? "100" : "120"'
color: '=items[props.maintoggle].state == "ON" ? props.color : "gray"'
- component: oh-toggle
item: =props.maintoggle
colorTheme: =props.color
- component: f7-block
style:
height: 35px
display: '=(props.grouptogglearray) ? "block" : "none"'
visible: "=(props.grouptogglearray) ? true : false"
slots:
default:
scrollbar: true
params:
slidesPerView: 1
direction: vertical
mousewheel: true
scrollbar:
hide: true
style:
width: 100%
height: 100%
slots:
default:
- component: oh-repeater
for: item
in: =props.grouptogglearray.split("|")
fragment: true
slots:
default:
style:
width: 100%
height: 100%
slots:
default:
- component: f7-col
class:
- display-flex
style:
width: 100%
height: 100%
slots:
default:
- component: f7-block-title
style:
margin-top: 10px
margin-bottom: -2px
slots:
default:
- component: Label
text: =loop.item.split("\"")[1]
f7: =props.icon
color: '=items[loop.item.split("\"")[3]].state == "ON" ? props.color : "gray"'
item: =(loop.item.split("\"")[3])
style:
height: 35px
display: '=(props.maintoggle) ? "block" : "none"'
- component: f7-card-footer
slots:
default:
- component: Label
text: =props.footer
Please let me see screenshots of what you are using them for
