Universal Toggle
I‘m still using it so I would say yes it is still supported. However I do not have an Android device so I never tested this. This sounds a bit weird, are there any fundamental differences in main ui depending on the OS? Anyone else using this widget on android?
Can you show the values of maintoggle und grouptogglearray please? Especially check if the quotes are correct, android might use ” instead of " for example.
You can try this hopefully more robust version though it is not thoroughly tested yet:
uid: universal_toggle_v5
tags: []
props:
  parameters:
    - description: Title of the card
      label: Title
      required: false
      type: TEXT
    - description: The card footer
      label: Footer
      required: false
      type: TEXT
    - description: Name of the Icon (see https://framework7.io/icons/ for available icons)
      label: F7 Icon
      required: true
      type: TEXT
    - description: Color scheme for icons and toggles (see https://framework7.io/docs/color-themes.html for available color schemes)
      label: Color
      required: true
      type: TEXT
    - context: item
      description: Main toggle item (use for single toggle or as main switch for group)
      label: Item
      required: false
      type: TEXT
    - description: 'Group toggles, format: "Label" "ItemName"|"Label2" "ItemName2"'
      label: Group toggle Array
      required: false
      type: TEXT
  parameterGroups: []
component: f7-card
  title: '=(props.title && props.title !== "undefined" && props.title !== "null") ? props.title : ""'
slots:
  default:
    - component: f7-card-content
      slots:
        default:
          - component: oh-context
              functions:
                # Prop is set (not empty, not the strings "undefined"/"null")
                hasMain: |-
                  =(x) => !['', 'undefined', 'null'].includes((''+props.maintoggle).trim())
                hasGroup: |-
                  =(x) => !['', 'undefined', 'null'].includes((''+props.grouptogglearray).trim())
                footerText: |-
                  =(x) => ['', 'undefined', 'null'].includes((''+props.footer).trim()) ? '' : props.footer
                # Split the group array; typographic quotes (Android keyboards) are normalized to "
                groupList: |-
                  =(x) => !['', 'undefined', 'null'].includes((''+props.grouptogglearray).trim()) ? (''+props.grouptogglearray).replace(/[„“”‟″«»]/g, '"').split('|').map(s => s.trim()).filter(s => s !== '') : []
                # Parse one entry: "Label" "Item" -> {label, item}; a plain item name also works
                entry: |-
                  =(s) => ((m, t) => ({label: m ? m[1] : t, item: m ? m[2] : t}))((''+s).replace(/[„“”‟″«»]/g, '"').match(/"([^"]*)"\s*"([^"]*)"/), (''+s).replace(/[„“”‟″«»"]/g, '').trim())
                # Item exists (avoids errors for typos or items that are not loaded yet)
                valid: |-
                  =(n) => !!items[n]
                # State is ON or a number > 0 (dimmer etc.)
                isOn: |-
                  =(n) => ((s) => s === 'ON' || (!isNaN(parseFloat(s)) && parseFloat(s) > 0))(items[n] ? items[n].state : undefined)
            slots:
              default:
                - component: f7-swiper
                    init: true
                    pagination: =(fn.hasMain() && fn.hasGroup())
                    params:
                      allowSlideNext: =fn.hasGroup()
                      allowSlidePrev: =fn.hasGroup()
                      allowTouchMove: =fn.hasGroup()
                      observeParents: true
                      observeSlideChildren: true
                      observer: true
                      pagination: '=(fn.hasMain() && fn.hasGroup()) ? {clickable: true} : false'
                      slidesPerView: 1
                      watchOverflow: true
                    style:
                      height: 175px
                      width: 100%
                  slots:
                    default:
                      # Slide 1: main toggle
                      - component: f7-swiper-slide
                          style:
                            height: 100%
                            width: 100%
                          visible: =fn.hasMain()
                        slots:
                          default:
                            - component: f7-col
                                class:
                                  - display-flex
                                  - flex-direction-column
                                  - align-items-center
                                  - justify-content-space-evenly
                                style:
                                  height: 100%
                                  width: 100%
                              slots:
                                default:
                                  - component: oh-link
                                      action: toggle
                                      actionItem: =props.maintoggle
                                      actionCommand: 'ON'
                                      actionCommandAlt: 'OFF'
                                      visible: =fn.valid(props.maintoggle)
                                    slots:
                                      default:
                                        - component: f7-icon
                                            color: '=fn.isOn(props.maintoggle) ? props.color : "gray"'
                                            f7: =props.icon
                                            size: '=(fn.hasGroup()) ? "100" : "120"'
                                  - component: oh-toggle
                                      colorTheme: =props.color
                                      item: =props.maintoggle
                                  - component: f7-block
                                      style:
                                        display: '=(fn.hasGroup()) ? "block" : "none"'
                                        height: 35px
                      # Slide 2: group toggles
                          style:
                            height: 100%
                            width: 100%
                          visible: =fn.hasGroup()
                        slots:
                          default:
                                params:
                                  direction: vertical
                                  mousewheel: true
                                  scrollbar:
                                    hide: true
                                  setWrapperSize: true
                                  slidesPerView: 1
                                scrollbar: true
                                style:
                                  height: 100%
                                  width: 100%
                              slots:
                                default:
                                  - component: oh-repeater
                                      for: item
                                      fragment: true
                                      in: =fn.groupList()
                                    slots:
                                      default:
                                            style:
                                              height: 100%
                                              width: 100%
                                          slots:
                                            default:
                                              - component: f7-col
                                                  class:
                                                    - display-flex
                                                  style:
                                                    height: 100%
                                                    width: 100%
                                                slots:
                                                  default:
                                                    - component: f7-block-title
                                                        style:
                                                          margin-bottom: -2px
                                                          margin-top: 10px
                                                      slots:
                                                        default:
                                                          - component: Label
                                                              text: =fn.entry(loop.item).label
                                                        action: toggle
                                                        actionItem: =fn.entry(loop.item).item
                                                        actionCommand: 'ON'
                                                        visible: =fn.valid(fn.entry(loop.item).item)
                                                      slots:
                                                        default:
                                                              color: '=fn.isOn(fn.entry(loop.item).item) ? props.color : "gray"'
                                                              f7: =props.icon
                                                        item: =fn.entry(loop.item).item
                                                        style:
                                                          display: '=(fn.hasMain()) ? "block" : "none"'
                                                          height: 35px
    - component: f7-card-footer
      slots:
        default:
              functions:
                footerText: |-
            slots:
              default:
                - component: Label
                    text: =fn.footerText()
