openHABian 3.3.0
RPi
In openhab.log I keep getting the error:
[ore.common.registry.AbstractRegistry] - Cannot add "RollershutterItem" with key "2ndBedroomRightBlinds_Shutter": The specified name of the item '2ndBedroomRightBlinds_Shutter' is not valid!
In an earlier version of openHab I was allowed to create two (as it turns out) invalid item names and associate them with channels in my roller shutter things. On upgrading to a more recent version, openHab made it clear that these items were not allowed (more error-checking was added, I suppose), so I deleted them and replaced them with SecondBedroomRightBlinds_Shutter. The original items was created in PaperUI, but the new ones are in an items file.
But I still got the errors in the log. So I looked on the forum and saw that there were a couple of commands:
openhab:links orphan list
openhab:links orphan purge
Sure enough, the offending items appeared there. I purged them. The error didn’t go away.
Then I tried clearing the cache. Same result.
So now I see that the items are still in:
/var/lib/openhab/jsondb/org.openhab.core.items.Item.json
Should I just edit it and delete them?
