- Platform information:
- Hardware: RPI 5 4Gb
- OS: OH5 Openhabian, openHAB 5.0.2 - Release Build
- Java Runtime Environment: what openhabian installed
- openHAB version: openHAB 5.0.2 - Release Build
- The installed bindings are Zwave, Zigbee, Astro, Network, Pushover, Basic UI, RRD4J, JavaScript Scripting and JRuby Scripting
I upgraded from a RPI3 running OH 4 to an RPI5 running OH5 a while back and it’s been working fine. I decided over the last week to clean up the install as there are a number of never deleted leftovers. I’ve been checking the log to find errors I created in the process and it’s all clean now but I have these seemingly meaningless errors and was wondering what they might be. All these errors only happen at startup:
I have 2 Fire TV boxes and I get these errors related to their IPs. Since the series occurs multiple times I may have them out of order as it’s not clear to me where they start and end
18:10:46.442[WARN] [org.jupnp.binding.xml.RecoveringUDA10DeviceDescriptorBinderImpl] - Regular parsing failed
18:10:46.535[WARN] [org.jupnp.binding.xml.RecoveringUDA10DeviceDescriptorBinderImpl] - Regular parsing failed
18:10:46.536[WARN] [org.jupnp.binding.xml.RecoveringUDA10DeviceDescriptorBinderImpl] - Removing leading garbage didn't work
18:10:46.587[WARN] [org.jupnp.util.SpecificationViolationReporter] - UPnP specification violation: No closing element in descriptor
18:10:46.618[WARN] [org.jupnp.binding.xml.RecoveringUDA10DeviceDescriptorBinderImpl] - Removing leading garbage didn't work
18:10:46.629[WARN] [org.jupnp.protocol.RetrieveRemoteDescriptors] - Could not hydrate device or its services from descriptor: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:NFANDROID2-PRV-FTVCUBE2022-AMAZOAFTGAZL-35467-034E5FA8C5BA486, Descriptor: http://xxx.168.xxx.xxx:9080, Root: true
18:10:46.634[WARN] [org.jupnp.util.SpecificationViolationReporter] - UPnP specification violation: No closing element in descriptor
18:10:46.670[WARN] [org.jupnp.protocol.RetrieveRemoteDescriptors] - Could not hydrate device or its services from descriptor: (RemoteDevice) Identity: (RemoteDeviceIdentity) UDN: uuid:NFANDROID2-PRV-FTVSTK-AMAZOAFTA-7348-E9561F58DD1344Z2C301ZC6ADD1E75A21, Descriptor: http://192.168.xxx.xxx:9080, Root: true
18:10:46.671[WARN] [org.jupnp.util.SpecificationViolationReporter] - UPnP specification violation: UPC must be 12 digits: '00000-00001' for device 'ProductAgent for Windows'
18:10:46.672[WARN] [org.jupnp.util.SpecificationViolationReporter] - UPnP specification violation: UPC must be 12 digits: '00000-00001' for device 'ProductAgent for Windows'
And then I have this error which refers to Node 17 and I’ve no idea where it might be coming from or how to go about looking as the Device that was Node 17 died and was removed long ago.
18:11:16.803[WARN] [org.openhab.binding.zwave.internal.protocol.ZWaveController] - NODE 17: Restore from config: Error. Data invalid, ignoring config.
Any suggestions welcome. None of it seems to be a problem but I’ve no idea why it might care about the Fire TVs as nothing related to them is installed. I’d be happier if I could get rid of them as it would make the log easier to read.
Thanks so much.
