Same here . I think the Binding must be Update by the Maintainer to support this Datapoint.
If the Datapoint is supported you can use this for Dimming or Rollershuter, I think.
Agree that it is listed as a datapoint. The thing is, that at the moment this message is listed in the log, the long_press action wouldn‘t be executed.
This is not the behavior I expect. But let’s wait for the developers…
I understand the button logic like the following (i didn’t check the times, these are just examples):
when a button is pressed only a short time, upon release the PRESS_SHORT channel is triggerd
when a button is pressed for let’s say 5 seconds, PRESS_LONG channel is triggered
when the button is still pressed 10 seconds later PRESS_CONT channel is triggered
when the button is released after PRESS_LONG was triggered, PRESS_LONG_RELEASE is triggered
Additional to this, there is also a PRESS datapoint. This one gets the values SHORT, LONG, CONT, LONG_RELEASE accordingly to the triggered channels. The enumeration behind this needs to be extended to include also the “CONT” value.
