I’ve got a z-wave motion sensor a while ago where the box says “Cyrus Smarthome Solutions” and the device carries a model identifier “ZUB_CYR10077”. After inclusion in openhab it shows up as unknown device.
Now I found Blog Posts and would try to go forward with adding the device to the database but there are some lose ends to me.
Starting with I don’t know where to fetch the XML. /var/lib/openhab/zwave does not contain an XML with the node id as added in openhab.
I’ve read that and did a manual wakeup to see if it changes anything. It didn’t first. So I just waited over night and now it was successfully identified as OpenSmartHouse Z-Wave Device Database
Glad it was found. I did check the deviceid in the DB, but forgot to check the Hex version so did not see that it was a clone.
One caution on the “wait” strategy for the future, the battery device initialization needs to get to a certain level (setting the wakeup interval) before waiting will work.
