Unlock openhab administration via port 8080
After a “successfull” downgrade from Openhab 3.4.2-1 to 3.3.0-1
I can’t unlock the administration in UI via port 8080
My initial page is available.
Via 8443 port I 'm still able to login and work on configurations or view page content
What can I do that button of administration opens login window?
My setup:
Raspberry Pi 3 Model B Rev 1.2
Linux raspberrypi 5.15.84-v8+ #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023 aarch64 GNU/Linux
total used free gemns. Puffer/Cache verfügbar
memory: 931460 591772 23940 7908 315748 356936
Swap: 3764220 222624 3541596
openjdk version “11.0.18” 2023-01-17
OpenJDK Runtime Environment (build 11.0.18+10-post-Raspbian-1deb11u1)
OpenJDK Server VM (build 11.0.18+10-post-Raspbian-1deb11u1, mixed mode)
Config:property-list
automation = pidcontroller
binding = onewire,ntp,smartmeter,shelly,avmfritz
misc = metrics
package = standard
persistence = influxdb
transformation = jsonpath
ui = basic,habpanel
By the way:
I made the downgrade to get rid of the constant message flow of shelly handler described
at Shelly Binding - #3014 by jabra_the_hut
This part was successfully! Log is empty. Shellie’s working fine.
A full reset of chrome is the solution.
