I have a new device that is unrecognized. It is an Inovelli on/off switch with scene control, but shows as Z-Wave Node 6 (0312:1E00:1E00:1.3)
I have another Inovelli switch NZW31S that is recognized and functions fine.
I am using openhab 2.4..0 Build #1323
Here is what I see
How can i get it to recognize the device?
I see in the binding that NZW30 and NZW30T are there:
I’m not sure how you managed to install such an old snapshot since 2.4 snapshots have not been produced for well over a year. The latest install is 2.5 so you should just be able to install that as per the OH documentation for whatever install you’re using (eg openHABian, Docker etc).
I have heard about issues with 2.5 OH upgrade so I haven’t done it yet. I just want the system to work.
I’ll look into upgrading now, but shouldn’t this switch work with the version I have now since the switch is including in the 2.4 Zwave binding?
The main issues are invalid bindings and people not reading the release notes or upgrade warnings.
I recommend uninstalling restdocs if you have it installed and reinstalling after upgrade. The location of that addon changed. Uninstalling it forst will save you some headaches later.
You existing binding should appear in the Paper UI. OPEnHAB is not designed to upgrade individual bindings. There is a Linux script ghere that helps some manually install a snapshot binding though.
No official document. Searching here should turn up threads. Windows 10 is not as well tested by the developers.
I followed all the steps and nothing changes. The Xstream link didn’t work so i downloaded the Xstream core from their website and put it in the addons folder.
btw there was nothing in the addons folder when i started - not sure if that effects anything or not. i still see the 2.4 binding in the paperui.
am i supposed to do something else after step viii?
