I am attempting to load z-wave, but have not had luck there. I have taken it back a step or two to try and get a clean working environment. I have uninstalled the z-wave binding.
While checking the logs both before and after, I notice that I am getting 3 instances of “Unresolved Requirement: Import package”, with 3 variations of the package “com.sun.jersey”:
com.sun.jersey.api.json
com.sun.jersey.core.header
com.sun.jersey.client
I searched the Maven repository and found the JAR for Jersey Client, 1.19 and 1.19.4. I am unsure if this is needed or if it is exactly the JAR, but it would make sense.
In any case, I have attempted various directories for the placement of this JAR to resolve the issue, and the error remains the same. (Starting with “addon” and then attempting a couple others within the “runtime” area, but to no avail.
PERHAPS this JAR is not the answer and there is something else missing. I am unsure. My Philips Hue lights are working and the Basic and Paper UIs are installed and working. My goal is to get the Z-wave working, but this may (or may not) be standing in the way).
Any help is appreciated.
The log contents is listed below:
2017-08-03 10:55:18.002 [ERROR] [org.openhab.io.habmin ] - FrameworkEvent ERROR - org.openhab.io.habmin
org.osgi.framework.BundleException: Could not resolve module: org.openhab.io.habmin [192]
Unresolved requirement: Import-Package: com.sun.jersey.api.json
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
2017-08-03 10:55:19.656 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.items'
2017-08-03 10:55:20.551 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2017-08-03 10:55:21.046 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.1.11:8080
2017-08-03 10:55:21.047 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.1.11:8443
2017-08-03 10:55:21.124 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-08-03 10:55:21.138 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-08-03 10:55:21.153 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-08-03 10:55:21.215 [ERROR] [com.sun.jersey.client ] - FrameworkEvent ERROR - com.sun.jersey.client
org.osgi.framework.BundleException: Could not resolve module: com.sun.jersey.client [197]
Unresolved requirement: Import-Package: com.sun.jersey.core.header; version="[1.19.0,2.0.0)"
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
2017-08-03 10:55:21.216 [ERROR] [com.sun.jersey.client ] - FrameworkEvent ERROR - com.sun.jersey.client
org.osgi.framework.BundleException: Could not resolve module: com.sun.jersey.client [198]
2017-08-03 10:55:26.204 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.thing.link.ThingLinkManager@23bdaaa0' takes more than 5000ms.
