I’ve started to receive a series of warnings in the logs:
[WARN ] [odel.deser.PropertyValueDeserializer] - Unsupported json value object, returning empty value
about one every 20 seconds. Doesn’t seem linked to any particular rule. I’m running a recent snapshot - #1418 - using the Ubuntu install package
Does anyone know what the cause might be, or how it could narrow it down to a particular rule/binding? (Other than remove everything and add it back in one-by-one, which would be a very slow process)
How many binding or rules are associated with the warning below?
I don’t know how many rules you have but you can comment them out using /* at the beginning and */ at the end of your rule, opposed to removing and re-adding.
I have an awful lot of rules, unfortunately - about 5,000 lines. But I don’t think it can be a rule, because all my rules carefully log status, and if a rule was running so frequently I would see that in the logs.
There’s also nothing odd in the events log.
And a google search for “odel.deser.PropertyValueDeserializer” only finds this post…
