nikoraes
(nikoraes)
December 9, 2018, 6:45pm
1
I get the following error:
Error during trainer initialization: Unsupported language: nl
Where does Habot read the language preference? Changing the language in the paper UI doesn’t seem to affect anything.
It would be great if a fallback language would also be supported.
ysc
(Yannick Schaus)
December 9, 2018, 10:43pm
2
Have you tried setting this setting explicitely to “English”? if you simply leave it blank I reckon it’ll use the language of the OS.
jimmyalias
(jimmy loyens)
December 24, 2018, 7:45pm
3
I get the same error, Tried setting language to English in paper ui, but still same error. Even after reboot.
ysc
(Yannick Schaus)
December 25, 2018, 2:10pm
4
That’s unfortunate - did you click Save (below the map) after setting it to English? Normally it should work
jimmyalias
(jimmy loyens)
December 25, 2018, 2:16pm
5
Unfortunatly i did. But i can wait. Happy holydays
jimmyalias
(jimmy loyens)
December 26, 2018, 7:10am
6
Hello, I found this on the forum: Cant change language - #3 by chris . Do you think this could be the problem? Im not shure what to put in the file for english. I gues replace “duser” with “english”, “nl” with “en” and “NL” with “US”? I will give it a try as soon as i can get to my server. I will keep you posted. Greets
ysc
(Yannick Schaus)
December 27, 2018, 5:51pm
7
I don’t think it matters. And I really don’t know what else to suggest, except try the next snapshot version, because I just merged Dutch translations by jongj · Pull Request #32 · openhab/org.openhab.ui.habot · GitHub which adds Dutch support to HABot!
