Good news! The chocolatey package will be updated soon by @bcurran3 to include only the standard openHAB distribution.
Using the “Install with Chocolatey” method described on Download openHAB | openHAB, OH2 will be installed without any pre-loaded (offline) addons and you will be able to install them as needed (using the PaperUI). See: Installation of Add-ons | openHAB
Thanks for this. I did a search for “tinyb” (used Agent Ransack) anywhere within the install (OpenHAB 2.5.5) on Win10, manual install. It appeared in three files:
‘69’ and ‘238’ are pseudo-random numeric assignments. A search tool is what is really required. Simply bouncing the system seems to cause some of these numbers to change.
I deleted the ‘mvn’ jar file, to no effect. I deleted the osgi bundle file and the problem was resolved.
A search of ‘Bluetooth’ shows a number of other Bluetooth jars.
As a result of deleting ‘bluez’ binding I still have 7 other Bluetooth bindings available to me, which I have yet to try to use, but I’m happy to see them, since I would still like to connect some Bluetooth devices. (The problem doesn’t appear to be Bluetooth, but the one particular binding.)
-AM43 Blind Drive Motor
-Bluetooth Device
-Connected Bluetooth Device
-Airthings Wave+
-Blukii SmartBeacon
-BlueGiga Bluetooth Dongle
-Ruuvi Smart Beacon
In addition, I had previously installed the SMA Energy Meter binding, which was not supposed to require any configuration, but had no visible result. Once I deleted the tinyb/Bluez bundle, I now have an SMA Energy Meter in my Inbox.
In addition, the reference within C:\openHAB2.5.5\userdata\cache\org.eclipse.osgi\framework.info.nn (now 73) cleared by itself and I have no references to ‘tinyb’. It’s unclear if it was necessary to delete the Bluez jar, but it clearly has no utility until the code is fixed.
