Update 2.0 to 2.1, my astro rules no longer work
After an update from openhab 2.0 to 2.1, my astro binding rules no longer work.
After the upgrade I had several problems, most I solved.
But my astro rule that used to work now no longer works.
I searched the forum but did not come up with any solutions.
In the Events.log log I see events related to the astro binding, so i assume that the binding is working.
2017-08-12 11:34:00.003 [ChannelTriggeredEvent     ] - astro:moon:home:set#event triggered END
2017-08-12 11:34:00.004 [ChannelTriggeredEvent     ] - astro:moon:local:set#event triggered END
Openhab.log:
2017-08-12 17:12:37.994 [WARN ] [el.core.internal.ModelRepositoryImpl] - Configuration model 'home1.rules' has errors, therefore ignoring it: [88,5]: no viable alternative at input 'channel'
[96,5]: no viable alternative at input 'channel'
Below my Astro rules
rule "Sun rise"
    channel 'astro:sun:home:rise#event' triggered START
    E0Voordeur_Switch.sendCommand(OFF)
    E1Somfy_Shutter.sendCommand(UP)
rule "Sun set"
    channel 'astro:sun:home:set#event' triggered START
    E0Voordeur_Switch.sendCommand(ON)
    E1Somfy_Shutter.sendCommand(DOWN)
any help is welcome
Think it should probably be capitalized?
    Channel ...
Thanks for your reply.
I’d tried that once.
What I notice is, that if I use a capital letter C the error in openhap.log is gone but the Eclipse Designer still disapproved it.
But he, it looks like the rule file is loading correctly.
But now I see the line below in openhab.log
2017-08-12 21:22:10.746 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'sunrise_Time' for widget org.eclipse.smarthome.model.sitemap.Text
Yay, progress!
So now you need to check your items file…
Again a lowercase letter where it should be a capital letter
Thx Namraccr
