Wanted to update via openhabian-config console. 7 packages are not able to install, with below failure. How to fix this?
2023-10-15_15:00:49_CEST [openHABian] Updating repositories and upgrading installed packages...
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
7 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
dpkg: could not open log '/var/log/dpkg.log': No space left on device
Setting up cpio (2.13+dfsg-7.1~deb11u1) ...
update-alternatives: error: cannot append to '/var/log/alternatives.log': No space left on device
dpkg: error processing package cpio (--configure):
installed cpio package post-installation script subprocess returned error exit status 2
Setting up openssh-client (1:8.4p1-5+deb11u2) ...
dpkg: error processing package openssh-client (--configure):
installed openssh-client package post-installation script subprocess returned error exit status 2
Setting up libblas3:armhf (3.9.0-3+deb11u1) ...
dpkg: error processing package libblas3:armhf (--configure):
installed libblas3:armhf package post-installation script subprocess returned error exit status 2
dpkg: dependency problems prevent configuration of openssh-sftp-server:
openssh-sftp-server depends on openssh-client (= 1:8.4p1-5+deb11u2); however:
Package openssh-client is not configured yet.
dpkg: error processing package openssh-sftp-server (--configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of liblapack3:armhf:
liblapack3:armhf depends on libblas3 | libblas.so.3; however:
Package libblas3:armhf is not configured yet.
Package libblas.so.3 is not installed.
Package libblas3:armhf which provides libblas.so.3 is not configured yet.
dpkg: error processing package liblapack3:armhf (--configure):
dpkg: dependency problems prevent configuration of ssh:
ssh depends on openssh-client (>= 1:8.4p1-5+deb11u2); however:
dpkg: error processing package ssh (--configure):
dpkg: dependency problems prevent configuration of openssh-server:
openssh-server depends on openssh-client (= 1:8.4p1-5+deb11u2); however:
openssh-server depends on openssh-sftp-server; however:
Package openssh-sftp-server is not configured yet.
dpkg: error processing package openssh-server (--configure):
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u7) ...
Errors were encountered while processing:
cpio
openssh-client
libblas3:armhf
openssh-sftp-server
liblapack3:armhf
ssh
openssh-server
Updating FireMotD available updates count ...
W: Problem unlinking the file /var/log/apt/eipp.log.xz - FileFd::Open (28: No space left on device)
W: Could not open file /var/log/apt/eipp.log.xz - open (17: File exists)
W: Could not open file '/var/log/apt/eipp.log.xz' - EIPP::OrderInstall (17: File exists)
W: Could not open file '/var/log/apt/term.log' - OpenLog (28: No space left on device)
E: Sub-process /usr/bin/dpkg returned an error code (1)
FAILED
