I would like to know if it is possible to trigger a rule from a client request (web UI, android app…).
My need : I setup a Wifi toggle rule which is working. But Wifi can be activated directly with the button on ISP box, and I did’nt find any way to publish something from this very box to let the bus know.
As I will need wifi state information only when I will display UI, I would like to trigger a check state on this “event” (UI display?).
The “regular” way would be to setup a Time cron rule to do that, but I would prefer an event-oriented approach.
Hope it’s clear and thanks for your replies,
Nicolas
