I installed openHAB 2 from the stable release, because snapshot-repository sounds a litte bit like a version which is not for production use.
But meanwhile I found some bugs, which where solved issues in github. So the snapshot-repository is obviously the one which has less bugs, or not?
I know that I don’t have to update every day, but I got mail-notifications from my auto-upgrade every day and that was irritating.
It is possible to switch between the stable and the snapshot-repository?
Perhaps I could switch to the snapshot-repository and do an update.
Optimally I could switch the apt-sources after the update back to the stable so that it won’t find any updates till there is a new stable release or I switched again to the snapshot-repository.
Yes. But have in mind that also new bugs could be introduced. Although I have never made any bad experience with that … and I am using the snapshot in production environment.
A standard openHAB installation does not have any upgrade notifications, so you must have installed some special tool …
Never heard about it … but that does not mean anything
Just disable it (or at least the notifications) if it is annoying you
Are you talking about this?: https://wiki.debian.org/UnattendedUpgrades
Oh, so downgrading is supported? Maybe I should try upgrading to snapshot as well then, knowing I have the possibility to go back if things don’t work out. I’m on 2.0 but most of my bindings are upgraded to snapshot versions anyway
Is there anyway to read up on what has changed between 2.0 stable and 2.1 snapshot?
I guess it would work, but since the stable repository only contains stuff that is older than the snapshot repository you would simply get no updates. So simply inactivating the oh repository completely would render the same effect…
Yes, you’re right. That’s the correct name of the feature. I use it to get notifications about security updates and so I get also notifications every day about a new snapshot-version. But I think I can configure the unattended upgrades to ignore openhab updates.
… or betwenn stable and testing repository.
That would be interesting for me too. So everyone could decide himself which the correct needed version is.
(Which bugs are fixed in snapshot repository but not yet in the testing repository)
Ok, I have to admit skimming the headers of those 200+ commits didn’t really say me much. I think I’ll simply wait until there’s a beta with some nice release notes
