With v5 being the latest version, how to I update my v4 to the latest (last) v4 without it auto-upgrading to v5?
Running openHABian 4.3.5 and just want to update it to 4.3.6.
sudo apt install openhab=4.3.6
sudo apt hold openhab
Thanks, unfortunately doesnât work
Version â4.3.6â for âopenhabâ was not found
So has 4.3.6 been removed from the repos?
No, no versions have been removed.
It might be 4.6.3-1.
Many thanks, that worked
Also updated the addons
sudo apt install openhab=4.3.6-1
sudo apt install openhab-addons=4.3.6-1
Unfortunately does not work for me even with the 4.3.6-1 version⌠Other ideas?
but i have to say that i donât use openhabianâŚ
Iâm not an expert with apt. I recommend searching âhow to install a specific version with aptâ and go though those tutorials to see if something is missing.
I was already on 4.3.6 when I did this so I just had to fix the version.
Well then you probably havenât configured the right repo for openHAB.
openHABian would have done that (and much more) for you.
apt-cache madison openhab will show you available packages. Which in turn depend on the repo(s) you have configured and how they match your hardware, neither of which @V60Grad has mentioned.
Thank you for taking a look at this. It was my mistake. I should have updated the package lists beforehand (apt update). Damn. I should have thought of that myself. Sorry for the confusion.
Edit: found it.. Its 4.3.7-1
Now its working
What´s the latest 4.3.x version.. I tried this, but it seems like 4.3.7 is not available, even though the download page say its 4.3.7
openhabian@openhabian:~ $ sudo apt install openhab=4.3.7
[sudo] password for openhabian:
Reading package lists... Done
Building dependency tree... Done
E: Version '4.3.7' for 'openhab' was not found
