I don’t know why, but yesterday I’ve decided to upgrade my synology to DSM7.3 and since that I’m facing the following errors and When I connect to the Karaf console , some more error occurs on simple command like LOG:Display or Log:tail ….
Before that bad idea, I was running fine with the same version of 5.0.1 , same config … but on DSM7.2.
It might be worth to mention also that I’m running Openhab 5.0.1 using the docker image
Could you provide me some guidance to solve the first 2 issues? here is the 2 stack trace
Level
ERROR
Logger Class
org.apache.karaf.shell.support.ShellUtil
Message
Exception caught while executing command
Stack Trace
java.lang.IllegalStateException: Unrecognized configuration
at org.apache.karaf.log.core.internal.LogServiceImpl.getDelegate(LogServiceImpl.java:71)
at org.apache.karaf.log.core.internal.LogServiceImpl.getLevel(LogServiceImpl.java:89)
at org.apache.karaf.log.command.LogTail$LogServiceTracker.addingService(LogTail.java:94)
at org.apache.karaf.log.command.LogTail$LogServiceTracker.addingService(LogTail.java:76)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:943)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:871)
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256)
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:321)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:264)
at org.apache.karaf.log.command.LogTail.execute(LogTail.java:54)
at org.apache.karaf.shell.impl.action.command.ActionCommand.execute(ActionCommand.java:88)
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:68)
at org.apache.karaf.shell.impl.console.osgi.secured.SecuredCommand.execute(SecuredCommand.java:86)
at org.apache.felix.gogo.runtime.Closure.executeCmd(Closure.java:599)
at org.apache.felix.gogo.runtime.Closure.executeStatement(Closure.java:526)
at org.apache.felix.gogo.runtime.Closure.execute(Closure.java:415)
at org.apache.felix.gogo.runtime.Pipe.doCall(Pipe.java:416)
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:229)
at org.apache.felix.gogo.runtime.Pipe.call(Pipe.java:59)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642)
at java.base/java.lang.Thread.run(Thread.java:1583)
and
Level
ERROR
Logger Class
org.openhab.core.io.rest.core.internal.JSONResponseExceptionMapper
Message
Unexpected exception occurred while processing REST request.
Stack Trace
at org.openhab.core.karaf.internal.LoggerResource.getLoggers(LoggerResource.java:89)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
at java.base/java.lang.reflect.Method.invoke(Method.java:580)
at org.apache.cxf.service.invoker.AbstractInvoker.performInvocation(AbstractInvoker.java:179)
at org.apache.cxf.service.invoker.AbstractInvoker.invoke(AbstractInvoker.java:96)
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:201)
at org.apache.cxf.jaxrs.JAXRSInvoker.invoke(JAXRSInvoker.java:104)
at org.apache.cxf.interceptor.ServiceInvokerInterceptor$1.run(ServiceInvokerInterceptor.java:59)
at org.apache.cxf.interceptor.ServiceInvokerInterceptor.handleMessage(ServiceInvokerInterceptor.java:96)
at org.apache.cxf.phase.PhaseInterceptorChain.doIntercept(PhaseInterceptorChain.java:307)
at org.apache.cxf.transport.ChainInitiationObserver.onMessage(ChainInitiationObserver.java:121)
at org.apache.cxf.transport.http.AbstractHTTPDestination.invoke(AbstractHTTPDestination.java:265)
at org.apache.cxf.transport.servlet.ServletController.invokeDestination(ServletController.java:234)
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:208)
at org.apache.cxf.transport.servlet.ServletController.invoke(ServletController.java:160)
at org.apache.cxf.transport.servlet.CXFNonSpringServlet.invoke(CXFNonSpringServlet.java:225)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.handleRequest(AbstractHTTPServlet.java:304)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.doGet(AbstractHTTPServlet.java:222)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:497)
at org.apache.cxf.transport.servlet.AbstractHTTPServlet.service(AbstractHTTPServlet.java:279)
at org.ops4j.pax.web.service.spi.servlet.OsgiInitializedServlet.service(OsgiInitializedServlet.java:102)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:799)
at org.eclipse.jetty.servlet.ServletHandler$ChainEnd.doFilter(ServletHandler.java:1656)
at org.ops4j.pax.web.service.spi.servlet.OsgiFilterChain.doFilter(OsgiFilterChain.java:113)
at org.ops4j.pax.web.service.jetty.internal.PaxWebServletHandler.doHandle(PaxWebServletHandler.java:334)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:600)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1624)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1440)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:505)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1594)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1355)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:234)
at org.ops4j.pax.web.service.jetty.internal.PrioritizedHandlerCollection.handle(PrioritizedHandlerCollection.java:96)
at org.eclipse.jetty.server.handler.gzip.GzipHandler.handle(GzipHandler.java:772)
at org.eclipse.jetty.server.Server.handle(Server.java:516)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:487)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:732)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:479)
at org.eclipse.jetty.server.HttpChannel.run(HttpChannel.java:439)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.produce(EatWhatYouKill.java:137)
at org.eclipse.jetty.http2.HTTP2Connection.produce(HTTP2Connection.java:193)
at org.eclipse.jetty.http2.HTTP2Connection.onFillable(HTTP2Connection.java:148)
at org.eclipse.jetty.http2.HTTP2Connection$FillableCallback.succeeded(HTTP2Connection.java:371)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164)
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034)
Many thanks for your help
your code goes here
