sipvoip
(Nathan Stratton)
November 26, 2018, 4:48pm
1
Just upgraded from org.openhab.binding.zwave_2.4.0.201805312220.jar to latest 2.4 zwave binding. I removed everything in /var/lib/openhab2/zwave/ and started things up. It took some time, but found all my devices, but I noticed in habmin all devices and the controller are grey.
mhilbush
(Mark)
November 26, 2018, 6:29pm
2
Was this the development version of the binding? If not, did you follow this procedure?
I have now merged the development version of the ZWave binding into master, so it will be available in the 2.4 snapshot version. If you are using the ZWave binding, please read this post as the binding contains some breaking changes so you will need to manually update your configuration.
Firstly though - the major enhancements (there are tons more smaller updates) -:
Security has been added using the S0 security class. This should allow all devices supporting security to be included into the…
sipvoip
(Nathan Stratton)
November 26, 2018, 7:30pm
3
Yep, now the only difference is that I am using text files for configs, is there anything in zwave.things that needs to change?
