Update to milestone 2.5.0 M5 failed
I just updated to 2.5.0 M5 via the package install steps in https://www.openhab.org/download/ .
After a restart the http port 8080 does not come up anymore. In the log /var/log/openhab2/openhab.log I see lots of errors like:
2019-11-24 11:44:25.953 [WARN ] [org.apache.karaf.shell.ssh.Activator] - Error starting activator
java.lang.IllegalStateException: Service not tracked for class interface org.osgi.service.cm.ConfigurationAdmin
Any idea what I can do from here?
Shut down OH, clear the cache & tmp folders and restart. The first start will take longer as it builds the cache.
Thanks … after deleting those two folders openhab comes up again.
Seems zigbee does not work anymore though I get lots of:
13:46:05.093 [ERROR] [2531.network.packet.ZToolPacketStream] - Packet parsing failed due to exception.
com.zsmartsystems.zigbee.dongle.cc2531.network.packet.ZToolParseException: Packet checksum failed
I assume that somehow my network key is lost now.
Christian
@chris please assist with this Zigbee issue.
I don’t think so - that’s not what the error is about anyway.
You should check the debug logs to find out what is happening - it’s hard to comment with such limited information.
Thanks for your reply. You are right. Seems it just took quite a while until it worked again.
Btw. I sometimes have a very high delay between clicking a switch in habpanel and the zigbee device reacting. Somtimes it happens almost instantly, sometimes it takes up to a minute. Any idea what might cause that? (I am using a CC2531EMK Coordinator)
Could this be related to the coordinator?
Christian
I’m having same problem - zigbee binding not working after upgrade. I had to downgrade back to 2.5 M3, no Idea what’s going on…
Not really. It could just be caused by queuing if there’s a lot going on, but I’m not sure without seeing a debug log. If you can capture the issue in a log, then I’ll be happy to look at it.
There was no change between these versions, so this probably isn’t the reason.
