I upgraded openHAB on my Raspberry Pi to 3.2 and installed the new JavaScript engine add-on. Now after a fresh start the installation is only responsive for a few minutes. The Log gets flooded with JavaScript errors:
2021-12-23 18:55:05.791 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: SyntaxError: js-joda.flow.js:9:8 Expected ; but found module
declare module "js-joda" {
js-joda.flow.js:10:12 Expected ; but found class
declare class TemporalAccessor {
js-joda.flow.js:11:17 Expected , but found :
get(field: TemporalField): number;
js-joda.flow.js:12:19 Expected , but found :
query(query: TemporalQuery): any;
js-joda.flow.js:13:19 Expected , but found :
range(field: TemporalField): ValueRange
js-joda.flow.js:14:4 Expected eof but found }
at org.graalvm.polyglot.Context.eval(Context.java:379) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:458) ~[?:?]
at com.oracle.truffle.js.scriptengine.GraalJSScriptEngine.eval(GraalJSScriptEngine.java:400) ~[?:?]
at javax.script.AbstractScriptEngine.eval(AbstractScriptEngine.java:249) ~[java.scripting:?]
at org.openhab.automation.jsscripting.internal.scriptengine.DelegatingScriptEngineWithInvocable.eval(DelegatingScriptEngineWithInvocable.java:56) ~[?:?]
at org.openhab.automation.jsscripting.internal.scriptengine.InvocationInterceptingScriptEngineWithInvocable.eval(InvocationInterceptingScriptEngineWithInvocable.java:79) ~[?:?]
at org.openhab.core.automation.module.script.internal.ScriptEngineManagerImpl.loadScript(ScriptEngineManagerImpl.java:177) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.createAndLoad(ScriptFileWatcher.java:231) ~[?:?]
at org.openhab.automation.jsscripting.internal.fs.watch.JSScriptFileWatcher.createAndLoad(JSScriptFileWatcher.java:57) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.importFile(ScriptFileWatcher.java:211) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.lambda$2(ScriptFileWatcher.java:203) ~[?:?]
at java.util.Optional.ifPresent(Optional.java:183) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.importFileWhenReady(ScriptFileWatcher.java:201) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.importResources(ScriptFileWatcher.java:148) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.importResources(ScriptFileWatcher.java:142) ~[?:?]
at org.openhab.core.automation.module.script.rulesupport.loader.ScriptFileWatcher.lambda$6(ScriptFileWatcher.java:286) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
2021-12-23 18:55:06.055 [ERROR] [ipt.internal.ScriptEngineManagerImpl] - Error during evaluation of script 'file:/etc/openhab/automation/js/node_modules/@js-joda/core/typings/js-joda.flow.js': org.graalvm.polyglot.PolyglotException: SyntaxError: js-joda.flow.js:9:8 Expected ; but found module
2021-12-23 18:55:06.091 [INFO ] [rulesupport.loader.ScriptFileWatcher] - Loading script '/etc/openhab/automation/js/node_modules/@js-joda/core/dist/js-joda.esm.js'
2021-12-23 18:55:06.158 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shelly25-roller:84cca8b081e4' to inbox.
2021-12-23 18:55:06.457 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shelly25-roller:c45bbe5f4878' to inbox.
2021-12-23 18:55:16.691 [INFO ] [control.internal.WebSocketConnection] - Web Socket close 1005. Reason: null
2021-12-23 18:55:35.974 [ERROR] [b.automation.script.javascript.stack] - Failed to execute script:
org.graalvm.polyglot.PolyglotException: SyntaxError: js-joda.esm.js:14874:0 Expected an operand but found export
export { ArithmeticException, ChronoField, ChronoLocalDate, ChronoLocalDateTime, ChronoUnit, ChronoZonedDateTime, Clock, DateTimeException, DateTimeFormatter, DateTimeFormatterBuilder, DateTimeParseException, DayOfWeek, DecimalStyle, Duration, IllegalArgumentException, IllegalStateException, Instant, IsoChronology, IsoFields, LocalDate, LocalDateTime, LocalTime, Month, MonthDay, NullPointerException, OffsetDateTime, OffsetTime, Period, ResolverStyle, SignStyle, Temporal, TemporalAccessor, TemporalAdjuster, TemporalAdjusters, TemporalAmount, TemporalField, TemporalQueries, TemporalQuery, TemporalUnit, TextStyle, UnsupportedTemporalTypeException, ValueRange, Year, YearConstants, YearMonth, ZoneId, ZoneOffset, ZoneOffsetTransition, ZoneRegion, ZoneRules, ZoneRulesProvider, ZonedDateTime, _, convert, nativeJs, use };
2021-12-23 19:04:14.404 [WARN ] [mazonechocontrol.internal.Connection] - Request to url 'https://alexa.amazon.de/api/np/player?deviceSerialNumber=G090XG12126203T6&deviceType=A1RABVCI4QCIKC&screenWidth=1440' fails with unknown error
java.net.SocketException: Datenübergabe unterbrochen (broken pipe) (Write failed)
at java.net.SocketOutputStream.socketWrite0(Native Method) ~[?:?]
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:110) ~[?:?]
at java.net.SocketOutputStream.write(SocketOutputStream.java:150) ~[?:?]
at sun.security.ssl.SSLSocketOutputRecord.flush(SSLSocketOutputRecord.java:251) ~[?:?]
at sun.security.ssl.HandshakeOutStream.flush(HandshakeOutStream.java:89) ~[?:?]
at sun.security.ssl.ClientHello$ClientHelloKickstartProducer.produce(ClientHello.java:658) ~[?:?]
at sun.security.ssl.SSLHandshake.kickstart(SSLHandshake.java:525) ~[?:?]
at sun.security.ssl.ClientHandshakeContext.kickstart(ClientHandshakeContext.java:107) ~[?:?]
at sun.security.ssl.TransportContext.kickstart(TransportContext.java:232) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:443) ~[?:?]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:421) ~[?:?]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:572) ~[?:?]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:197) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1592) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1520) ~[?:?]
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:527) ~[?:?]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:334) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:639) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:555) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:550) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getPlayer(Connection.java:1107) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.updateState(EchoHandler.java:851) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.refreshData(AccountHandler.java:571) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.AccountHandler.checkData(AccountHandler.java:455) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:305) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) [?:?]
2021-12-23 19:08:08.513 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@4fb8da' takes more than 5000ms.
2021-12-23 19:08:08.515 [WARN ] [ab.core.internal.events.EventHandler] - Dispatching event to subscriber 'org.openhab.core.internal.items.ItemUpdater@4fb8da' takes more than 5000ms.
This is only a small fragment of the log. Thereās lots of stuff like that. Right now the openHAB is useless Iād appreciate any advice on how to resolve this messā¦
