- Platform information:
- Hardware: Rpi4/4GB/SD card
- OS: openHABian
- Java Runtime Environment: 11
- openHAB version: 3.4.4
- Issue of the topic:
my log stopped working after I added new items. I had the issue before some years ago and it was caused by ZRAM exceeding the mem_limit. In the past it helped to increase the mem_limit and disk_size in ztab.
I checked ztab again and I saw that it still had a target_dir of openhab2/persistence, which does not exist anymore. This is my config before I did some changes:
# swap alg mem_limit disk_size swap_priority page-cluster swappiness
swap lzo-rle 200M 600M 75 0 150
# dir alg mem_limit disk_size target_dir bind_dir
dir lzo-rle 150M 1000M /var/lib/openhab2/persistence /persistence.bind
# log alg mem_limit disk_size target_dir bind_dir oldlog_dir
log lzo-rle 300M 500M /var/log /log.bind
So, I updated it to the target_dir to “/var/openhab/persistence” and changed the algorithm of “dir” and “log” from “lzo-rle” to “zstd” (I saw on github that zstd is used instead of lzo-rle…). Furthermore I reduced the log-size from 16 to 10 MB,
But openhab, zigbee2mqtt and mosquitto did not start anymore because of missing log folders/files. All log files in the log-folder were removed. I did not want to fix everything so I used a backup.
Now my questions:
- should I update the target_dir? If yes, how? Just add an additional line? Or modify the existing line?
- does it make sense to update the algorithm?
- the relation of mem_limit = 150M and disk_size = 1000M does not really fit. Can I change it to 300M and 500M?
Sorry, I am not really an expert using ZRAM…
Thanks and best regards,
Tim
