I have a weird problem,
I’ve installed fibaro double switch 2 and tried to set the configuration of association group of the lifeline to openhab controller through the habmin (I’m using latest snapshot of zwave binding).
after changing it and clicking save I’m getting the message "Thing saved successfully"
but next time when I’m refreshing the page I see the change was not saved…
tried a few times, same thing happen again and again.
logs shows are:
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update received
[DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update group_1 to node_1_0
[ERROR] [ome.io.rest.core.thing.ThingResource] - Exception during HTTP PUT request for update config at ‘things/zwave:device:Zwave:node5/config’ for thing ‘zwave:device:Zwave:node5’: null
Any ideas?
Thanks!
