Updates to String Items not Triggering Rules
I have two string items that I want to monitor to determine whether my house is in “vacation mode” in my Ecobee thermostats. I have written the rule to run on update, rather than change, so that the variable is correctly initialized after a restart. Below is my rule (I added the pushover line to double-check that the rule is not being run):
rule "Update sOnVacation"
Item tDiningRoomEventType updated or
Item tDiningRoomEventName updated
pushover(“Test - Vacation Variables Updated.”)
if ((tDiningRoomEventType.state.toString.toUpperCase() == “VACATION”) &$
sendCommand(sOnVacation, OFF)
} else {
sendCommand(sOnVacation, ON)
The items are being updated every three minutes:
2016-04-01 13:48:27 - tDiningRoomEventName state updated to Uninitialized
2016-04-01 13:51:29 - tDiningRoomEventType state updated to Uninitialized
But the rule is never triggered. Again, the two items are string items. Am I missing something or is there a bug with respect to updates to string items?
I should add that I also tried changing the value to an arbitrary value (“HA”) and that did not trigger the rule either:
2016-04-01 14:01:37 - tDiningRoomEventType state updated to HA
Should it be received update instead of updated?
Yes, I just caught that. That’s what I get for assuming that I know the syntax off the top of my head!
Gets me too often as well!
