Updating npm does not work
openhabian 2024-03-16T22:19:25+01:00}(b09cef5) on Raspi 3+
I ran openhabian-config to do an update. Everything was working fine. I realized a message, which asked me to update npm.
So i did a
npm install -g npm@10.5.0
as requested and got the following error messages:
npm ERR! code EBADENGINE
npm ERR! engine Unsupported engine
npm ERR! engine Not compatible with your version of node/npm: npm@10.5.0
npm ERR! notsup Not compatible with your version of node/npm: npm@10.5.0
npm ERR! notsup Required: {“node”:“^18.17.0 || >=20.5.0”}
npm ERR! notsup Actual: {“npm”:“8.19.4”,“node”:“v16.20.2”}
npm ERR! A complete log of this run can be found in:
npm ERR! /home/openhabian/.npm/_logs/2024-03-26T08_43_55_781Z-debug-0.log
Maybe my npm version is older as expected. I can’t remember to have been ask to update npm before. Hm, you never know.
Is there any advice what to do?
not sure but why install with npm? What happens after
sudo apt-get install npm
While starting up “openhabian-config → 2 Upgrade System” i got the message to update as shown.
Via apt i get
Die folgenden Pakete haben unerfüllte Abhängigkeiten:
libnode72 : Kollidiert mit: nodejs-legacy
nodejs : Kollidiert mit: npm
E: Probleme können nicht korrigiert werden, Sie haben zurückgehaltene defekte Pakete.
So there seems to a problem with old npm/node.js versions.
I would try to remove node and npm and reinstall with apt.
After removing nodejs via apt, some dependencies stayed and “apt install …” still did not work (same error). So i installed nodejs manually.
After this i did another “apt install …”. No errors and everthing seems to be fine. No log errors, no strange system behaviour … up to now.
I red some stuff about problems with old versions which made me go for the manual install. Not a good idea normally. But it seemed to wok in this case.
Thanks for your support.
The same for me.
2025-01-21_22:03:30_CET [openHABian] Checking for updates of openhab_rules_tools for JS Scripting... npm notice
npm notice New major version of npm available! 9.6.7 -> 11.0.0
npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.0.0
npm notice Run npm install -g npm@11.0.0 to update!
npm notice
If I run …
… I get the same dependency problems
npm ERR! engine Not compatible with your version of node/npm: npm@11.0.0
npm ERR! notsup Not compatible with your version of node/npm: npm@11.0.0
npm ERR! notsup Required: {"node":"^20.17.0 || >=22.9.0"}
npm ERR! notsup Actual:   {"npm":"9.6.7","node":"v18.17.1"}
I need some help for this.
If I use openhabian-config again, then there are no updates found.
Strange…
2025-01-21_22:33:26_CET [openHABian] Checking for updates of openhab_rules_tools for JS Scripting... No update available.
If openHAB runs without errors, there is no need to update npm. That is what i think now.
I assume you need to update nodejs first?
In case your hardware is a Pi, I think npm is supported until npm version 10.x only, which requires nodejs v18
