Updating Ring Gen2 Door/Window Sensor in the Database
Ok done.
As you are new (Welcome by the way!), the process is the ZW DB periodically is merged into the binding (I believe a merge by the developer will be soon, but I really don’t know). Then you will need to bundle:update your ZW binding (updates are not backported). The process for that is in the docs here. Bundle Management | openHAB. The location of the ZW bundles are here (copy link to the .jar). openHAB-ZWave [Jenkins].
If you are in a hurry and adventurous :wink: You can follow this procedure. The last folder would be /ring (not /zooz) and the file is this (updated with 0601)
4sd2sz0en0_0_0.xml (7.2 KB)
