- Platform information:
- Hardware: VM with 4 cores from i5 2400 /2Gb/15Gb
- OS: LXQt 0.15.0
- Java Runtime Environment: Zulu11.48+21-CA (build 11.0.11+9-LTS)
- openHAB version: 3.1.0-1
- Binding used: HTTP Binding 3.1.0
- Issue: Hello everyone, apologies if I am writing something incorrectly here, this is my first post of this kind…
Since the update to 3.1.0-1, whenever a state update is sent to an item, a command is sent instead. I will display one rule here as an example but this happens to every rules. For now I have all these kind of rules disabled.
I have tried to downgrade to previous available versions even back to 3.0.0 but the issue remains. - Configurations:
Items configuration: (applies to BedsdideLamps, BedroomLights, DeskLamp)
class: Point_control
relatesTo: Property_Light
Amazon Alexa: Lighting
Apple HomeKit: Lighting.Lighting.Brightness -
Rules code related to the issue:
- id: "1"
configuration:
command: ON
itemName: DeskLamp
type: core.ItemCommandTrigger
- id: "2"
configuration:
itemName: BedsideLamps
command: ON
- id: "3"
configuration:
itemName: BedroomChandelier
command: ON
conditions: []
actions:
- id: "4"
configuration:
itemName: BedroomLights
state: ON
type: core.ItemStateUpdateAction ```
* Logs:
``` 2021-07-07 15:26:58.349 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BedsideLamps' changed from 100 to 0
2021-07-07 15:26:58.350 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BedroomLights' changed from 100 to 0
2021-07-07 15:27:04.746 [INFO ] [openhab.event.ItemCommandEvent ] - Item 'BedsideLamps' received command ON
2021-07-07 15:27:04.751 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item 'BedsideLamps' predicted to become ON
2021-07-07 15:27:04.757 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BedsideLamps' changed from 0 to 100
2021-07-07 15:27:04.760 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'BedroomLights' changed from 0 to 100 ```
