- Platform information:
- Hardware: Raspberry Pi 3 Model B Rev 1.2
- OS: Raspbian GNU/Linux 8 (jessie)
- openHAB version: 2.3.0~20180113162733-1 (Build #1181)
- Topic Summary:
- I have a Yamaha stereo that cannot be managed via the Yamaha binding (other than Power). I used proxy items per @rlkoshak assistance and sendHttpGetRequest and sendHttpPostRequest commands in the rules files for fixed settings and python scripts to automate a number of use cases. Below is an example of my current configuration
Switch YamahaPwr "Kitchen Radio" [ "Switchable" ]
Frame label="Kitchen Radio" {Switch item=YamahaPwr}
var String URLCRXN560 = "http://192.168.128.199/YamahaRemoteControl/ctrl"
var String xmlheader = '{?xml version="1.0" encoding="utf-8"?}'
var String PowerOn = '{<YAMAHA_AV cmd="PUT"><System><Power_Control><Power>On</Power></Power_Control></System></YAMAHA_AV>}'
var String PowerOff = '{<YAMAHA_AV cmd="PUT"><System><Power_Control><Power>Standby</Power></Power_Control></System></YAMAHA_AV>}'
/* Yamaha Reciever Power */
rule "YamahaPwr"
Item YamahaPwr received update
if(YamahaPwr.state==ON){sendHttpPostRequest(URLCRXN560,xmlheader,PowerOn)}
else if(YamahaPwr.state==OFF){sendHttpPostRequest(URLCRXN560,xmlheader,PowerOff)}
Here is an example how one can adjust power level or source inputs via Http.. First is to get the http payload. In this case it is xml. I need insert a variable where the nine is located in this string.
var String VolLvlAM = '{<YAMAHA_AV cmd="PUT"><System><Volume><Lvl>9</Lvl></Volume></System></YAMAHA_AV>}' //Fixed Example
Instead of formatting and doing transformations, I ended up with splitting the string and concatenating the item.state value in the rule section.
var String VollvlPre = '{<YAMAHA_AV cmd="PUT"><System><Volume><Lvl>'
var String VollvlSuf = '</Lvl></Volume></System></YAMAHA_AV>}'
I’m thinking that that item entry would be
Dimmer Volyamaha "Kitchen Radio Volume" [ "Switchable" ]
Slider item=Volyamaha label="Volume" icon="none" }
Make sure the item.sate is converted to a string. In my case it was “Volyamaha.state.toString”
/* Yamaha Change Volume */
rule "Vol4Yamaha"
Item Volyamaha received update
value = Volyamaha.state.toString
VollvlVar = VollvlPre + value + VollvlSuf
sendHttpPostRequest(URLCRXN560,xmlheader,VollvlVar)
Solved
