Hi!
I updete my openHAB, and after that this happend:
The basic ui disappear and apear again after several seconds. The IOS app drops error (Response satus code was unacceptable: 503)
Can somebody help me? Thanks!
Hi!
Have you watched the startup log after the upgrade for any errors/issues?
Often two or more full startups are needed after an upgrade. If 2-3 full restarts of OH, without any issues in the log remaining, still won’t help, you might want to clear the cache and restart.
All the best.
Hi!
Ok, I try reboot it.
How can I clear the cache?
You should checkout past posts about addons.cfg entries, in particular about REST API location.
Best to
https://community.openhab.org/search?q=how%20to%20clear%20the%20cache
or
https://community.openhab.org/search?q=problem%20after%20upgrading
but
Stop openHAB : sudo systemctl stop openhab2.service
Clear cache: sudo openhab-cli clean-cache
Start openHAB again: sudo systemctl start openhab2.service
Thanks!
I start over, the whole process, and it’s worked!
Thanks everyone!
