Hi
I just tried to upgrade from 3.2 to 4.x (latest, I think 4.1 that is).
My Environment
- Synology: DSM 7.1.1-42962 Update 6
- Device: DS918+
- Installation Documentation used: Synology DiskStation | openHAB
Problem.
When I start the container everything seems to look fine, although I cannot connect to openhab from local network like it was possible before the update. http://192.168.178.32:8080 returns:
Die Website ist nicht erreichbar
192.168.178.32 hat die Verbindung abgelehnt.
I can connect other docker containers via the same browser in the same network though.
Analysis
When I configured it to use bridge I set the 8080 container port to local port 8080.
Contents of the upgrade log:
Image and userdata versions differ! Starting an upgrade.
You can find backup of userdata in /openhab/userdata/backup/userdata-2023-12-27T09-23-34.tar
openHAB Docker update script
The script will attempt to update openHAB to version 4.1.0
Please read the following e[32mnotese[m and e[31mwarningse[m:
Important notes for version 3.3.0:
e[31mWarning:e[m BMW ConnectedDrive Binding: BMW replaced ConnectedDrive Smartphone App with MyBMW Application. Underlying API is now disabled and the Binding isn't working anymore. Switch to new introduced MyBMW Binding recommended.
e[31mWarning:e[m Daikin Binding: The channel 'specialmode-powerful' has been removed, and a r/w channel 'streamer' added. The channel 'specialmode' changed to read/write to control eco/powerful mode.
e[31mWarning:e[m DanfossAirUnit Binding: The type of the channel 'humidity' was updated. You may need to remove and create your things again in case your things were previously created using UI and you want to use this channel.
e[31mWarning:e[m Helios Binding: Firmware versions older than v2.21 are no longer supported.
e[31mWarning:e[m JS Scripting Automation: 'item.history.lastUpdate()' returns 'time.ZonedDateTime' instead of 'Date'
e[31mWarning:e[m JS Scripting Automation: 'addItem(...)' and 'updateItem(...)' use new itemConfig as parameter and 'createItem(...)' was removed
e[31mWarning:e[m MQTT Binding: Support for the MQTT System Broker has been removed. Replace 'mqtt:systemBroker' things with 'mqtt:broker' things.
e[31mWarning:e[m Netatmo Binding: Things hierarchy and organization has changed as well as channel namings. You will need to remove and create again these things.
e[31mWarning:e[m OmniLink Binding: The channel 'sysdate' has been renamed to 'system_date', and is now read only, to make these changes visible you may need to remove and recreate the `controller` thing. To synchronize the controller time there is now a new action synchronizeControllerTime that can be used with a time zone input (e.g. 'America/Denver').
e[31mWarning:e[m Opentherm Gateway Binding: The 'otgw' Thing has been removed and split into a new 'openthermgateway' Bridge, and a new 'boiler' Thing. You will need to change your Thing and respective Item definitions.
e[31mWarning:e[m RFXCOM Binding: The channel 'fanSpeed' of 'fan_lucci_dc' and 'fan_novy' has been renamed to 'fanSpeedControl', and 'fan_lucci_dc' has a new numeric channel 'fanSpeed'. You may need to remove and create your things again.
e[31mWarning:e[m TapoControl Binding: L510_Series and L530_Series Things were renamed to L510 and L530 because of manufacturer changed naming with new HW-rev. You may need to remove and create again these things.
e[31mWarning:e[m WLED Binding: Binding now uses Bridge and Thing structure. Delete and add a new bridge, and at least 1 thing for each segment you require.
Important notes for version 3.4.0:
e[31mWarning:e[m CORE: Default units have been added for all dimensions. A state description defining the unit should be added to each item that uses a different unit.
e[31mWarning:e[m Automower Binding: Due to Husqvarna Authentication API change, bridge now requires application secret instead of username and password. Delete any existing bridge and re-add it, please make sure to update all automower things to use the newly added bridge.
e[31mWarning:e[m JavaScript Scripting Automation: 'setTimeout' and 'setInterval' return a timerId (a positive integer value) as in standard JS instead of an openHAB Timer.
e[31mWarning:e[m JavaScript Scripting Automation: ItemHistory min/max between/since returns now a number instead of a string.
e[31mWarning:e[m JavaScript Scripting Automation: openHAB JavaScript library versions < 3.1.2 are not fully compatible anymore. If you have manually installed the JS library, please upgrade to a version >= 3.1.2.
e[31mWarning:e[m JRuby Scripting Automation: The default `RUBYLIB` directory has changed to OPENHAB_CONF/automation/ruby/lib. Either explicitly configure the add-on to use the previous value, or move any files to the new location.
e[31mWarning:e[m Konnected Binding: Things needs to be recreated because of added Konnected Pro panel support and manual configuration of things.
e[31mWarning:e[m LG webOS Binding: The undocumented action "sendRCButton" was removed while it is possible to achieve the same action with "sendButton"
e[31mWarning:e[m Miele@home Binding: The channel 'start' now contains date and time for start of scheduled program. Previously it was counting down duration until the program would start.
e[31mWarning:e[m Miele@home Binding: The channels 'duration', 'elapsed' and 'finish' are now Number:Time. You may need to remove and create your things again in case your things were previously created using UI and you want to use these channels. Linked items need to be recreated.
e[31mWarning:e[m Resol Binding: Item Type of solar controllers channels using time and weekday format changed from Date to String. Items need to be adjusted accordingly.
e[31mWarning:e[m Systeminfo Binding: Multiple Number channels now have a dimension added. You may need to remove and create your things again in case your things were previously created using UI and you want to use these channels. Linked items need to be recreated.
e[31mWarning:e[m Systeminfo Binding: The default state description for DataAmount channels is now MiB. If you relied on MB, you may need to adjust.
e[31mWarning:e[m Velux Binding: On window things the semantic category of the position channel has been corrected from 'blinds' to 'window'. Window things with such channels that had been created via the UI will need to be deleted and re-created.
e[31mWarning:e[m Xiaomi Wifi devices (Mi IO) Binding: Channel Type change for some yeelights. The brightness channels with the Number type now have the Dimmer type. This affects only nightlight and ambilight channels for some models.
Important notes for version 4.0.0:
e[31mWarning:e[m CORE: core.GenericEventTrigger and core.GenericEventCondition parameters have have changed. See https://www.openhab.org/docs/configuration/rules-ng.html#system-module-types.
e[31mWarning:e[m CORE: Rules are now triggered by ItemStateUpdatedEvent instead of ItemStateEvent. If you use JSR223 scripting without helper libraries and expect a certain Java type, code changes might be needed.
e[31mWarning:e[m CORE: The syntax for an item category/icon in a textual configuration file no longer accepts a value enclosed in quotes. So <temperature> is valid but not <"temperature">. Please update the definition of your items if necessary.
e[31mWarning:e[m CORE: SCRIPT transformation has been removed and replaced with language-specific transformations: JS, RB, PY, DSL, GROOVY, etc. See https://www.openhab.org/docs/configuration/transformations.html#script-transformation
e[31mWarning:e[m CORE: UoM has been refactored. Please consult https://www.openhab.org/docs/concepts/units-of-measurement.html and https://www.openhab.org/docs/installation/#upgrading BEFORE starting openHAB, otherwise your persisted data may be corrupted.
e[31mWarning:e[m Airthings Binding: The channels `radon_st_avg` and `radon_lt_avg` are now of dimension `RadiationSpecificActivity` instead of `Density`. Please update your linked items accordingly.
e[31mWarning:e[m Bosch Indego Binding: Due to changes in the cloud services, the authentication method has changed. Please follow the authorization flow described in the documentation. Furthermore, a bridge is now required and must be assigned to the `indego` thing. Configuration of username and password is no longer required/supported.
e[31mWarning:e[m ComfoAir Binding: The channel `enthalpy#enthalpyTime` now represents the set time (in minutes) instead of the internal number value that is sent to the device (`minutes / 12`).
e[31mWarning:e[m DanfossAirUnit Binding: The deprecated channel 'manual_fan_speed' has been removed. Please use channel 'manual_fan_step' introduced in 3.2.
e[31mWarning:e[m Dark Sky Binding: Due to EOL of their API, this add-on has been removed.
e[31mWarning:e[m Generac MobileLink Binding: Due to an API change, existing Generator Things will need to be deleted and added again. Additionally, existing Items will need to be adjusted to reflect the updated Generator Thing channels.
e[31mWarning:e[m HomeKit: Add-on wide configuration of mappings for thermostat modes is no longer supported. Please use item-level configuration as described in the README.
e[31mWarning:e[m Hue emulation: The uniqueid value has been changed to resolve discovery issues with Alexa. You may need to rediscover "devices" in all services that use the hue emulation (Amazon Echo, Logitech Harmony, etc).
e[31mWarning:e[m Hunter Douglas (Luxaflex) PowerView Binding: Deprecated scene channels have been removed. Please use the scene channels introduced in 3.2 (in channel group 'scenes').
e[31mWarning:e[m JavaScript: JavaScript engines have changed their MIME types: NashornJS is application/javascript:version=ECMAScript-5.1 and GraalJS is application/javascript. Please update your scripts to either make them compatible with GraalJS or change the MIME type to continue to use NashornJS. For Blockly migration, visit the Blockly documentation.
e[31mWarning:e[m JavaScript NashornJS: NashornJS has been removed from core and isn't included by default. If you still need or want to use it, you can install it as an addon.
e[31mWarning:e[m JavaScript Scripting Automation: The old "metadata" and "itemchannellink" APIs have been replaced by a new API with extended functionality on the "items" namespace.
e[31mWarning:e[m JavaScript Scripting Automation: ItemHistory: historicState, maximumBetween, maximumSince, minimumBetween, minimumSince & previousState now return a HistoricItem instead of just the state. previousStateTimestamp has been removed, the timestamp is available on the HistoricItem.
e[31mWarning:e[m KNX Binding: Units of Measurements have been introduced, make sure you use correct units in the state description. Rules may need to be adapted. Several items changed from PercentType to QuantityType, i.e. raw values increase by a factor of 100.
e[31mWarning:e[m LuftdatenInfo Binding: The binding was renamed to Sensor.Community Binding to match the new naming of the service. Things need to be recreated.
e[31mWarning:e[m Netatmo Binding: Due to API authorization process change scheduled on the 2023/04/17 - refresh Token is no more stored in thing configuration, thus can be removed from things config files. If it remains, it'll be ignored.
e[31mWarning:e[m Netatmo Binding: New scope has been added for the introduction of the Carbon Monoxide Alarm. Authorization process has to be replayed (and former refreshToken can be removed from things config files -- see above).
e[31mWarning:e[m Windcentrale Binding: The binding has been reworked to support the new API that requires authentication. Delete old 'mill' Things, add an 'account' Bridge and add new 'windmill' Things using the 'account' as Bridge. The channel names now follow the naming conventions. Items must be adapted for these changes.
Important notes for version 4.1.0:
e[31mWarning:e[m Action Template Interpreter: removed from the distribution, functionality is covered by the Standard Interpreter.
e[31mWarning:e[m Energi Data Service Binding: The channels 'net-tariff' and 'transmission-net-tariff' have been renamed to 'grid-tariff' and 'transmission-grid-tariff' respectively. Items should be relinked to the new channels.
e[31mWarning:e[m Hue Binding: The auto update policy for API v2 light channels has been changed to avoid multiple state updates. For this to work, you may need to remove and create your things again in case your things were previously created using UI.
e[31mWarning:e[m JavaScript Scripting Automation: The "useIncludedLibrary" configuration parameter has been renamed to "injectionCachingEnabled". In case you changed it, make sure to apply that change to the new parameter.
e[31mWarning:e[m JDBC Persistence: The add-on now uses H2 database 2.2. If you use H2 for storing data, your database needs to be migrated as described in https://h2database.com/html/migration-to-v2.html. It is also required to add '
e[31mWarning:e[m LuxtronikHeatpump Binding: The channel 'controlSignalCirculatingPump' has been changed to type 'Number:Dimensionless'. Items linked to this channel will need to have their Type manually updated.
e[31mWarning:e[m Miele@home Binding: The channel 'powerConsumption' has been renamed to 'energyConsumption'. Items should be relinked to the new channel.
e[31mWarning:e[m MQTT EspMilightHub Binding: Colour bulbs no longer have a `level` channel. You may need to re-add your things for it to be removed. Link to the `colour` channel instead, even for `Dimmer` items.
e[31mWarning:e[m MyBMW Binding: Vehicle channels "charge-info" and "motion" removed, "charge-remaining", "last-fetched", "estimated-fuel-l-100km" and "estimated-fuel-mpg" added. Image options changed - now "VehicleStatus", "FrontView", "RearView", "FrontLeft" and "FrontRight" are available.
e[31mWarning:e[m Porcupine Keyword Spotter: removed from the distribution, it was unmaintained.
e[31mWarning:e[m Twitter Binding has become X. All related references to Twitter and Tweets have been replaced, please check your configuration (rules, actions, channels etc).
Performing pre-update tasks for version 4.0.2:
Adding '.bak' to /openhab/userdata/etc/log4j2.xml
Using default file /openhab/userdata/etc/log4j2.xml
Replacing userdata system files with newer versions...
Clearing cache...
Performing post-update tasks for version 3.3.0:
Performing post-update tasks for version 3.4.0:
Performing post-update tasks for version 4.0.0:
Replacing: String ,javascript to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String javascript, to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String javascript to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String ,cometvisu-php to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String cometvisu-php, to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String cometvisu-php to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String ,innogysmarthome to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String innogysmarthome, to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String innogysmarthome to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String ,imperihome to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String imperihome, to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String imperihome to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String ,darksky to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String darksky, to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String darksky to in file /openhab/userdata/config/org/openhab/addons.config
Performing post-update tasks for version 4.1.0:
Replacing: String actiontemplatehli, to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String ,actiontemplatehli to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String actiontemplatehli to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String ,porcupineks to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String porcupineks, to in file /openhab/userdata/config/org/openhab/addons.config
Replacing: String porcupineks to in file /openhab/userdata/config/org/openhab/addons.config
Starting JSON database update...
[main] INFO org.openhab.core.tools.internal.Upgrader - Copying item unit from state description to metadata in database '/openhab/userdata/jsondb/org.openhab.core.items.Item.json'
[main] INFO org.openhab.core.tools.internal.Upgrader - Stereoanlage1_Power: Could not find thing for channel 'tapocontrol:P110:b305cd4052:54AF977CB69A:energy#actualPower'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Stereoanlage1_TodayUsage: Could not find thing for channel 'tapocontrol:P110:b305cd4052:54AF977CB69A:energy#todayEnergyUsage'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@737996a0'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - Synology_TodayRuntime: Could not find thing for channel 'tapocontrol:P110:c69109542a:energy#todyRuntime'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@61dc03ce'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - Kaffeemaschine_EnergyUsage: Could not find thing for channel 'tplinksmarthome:hs110:C689B4:energyUsage'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Stereoanlage1_TodayRuntime: Could not find thing for channel 'tapocontrol:P110:b305cd4052:54AF977CB69A:energy#todyRuntime'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@50f8360d'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - Stereoanlage2_Power: Could not find thing for channel 'tapocontrol:P110:b305cd4052:54AF977CBAB8:energy#actualPower'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Synology_TodayUsage: Could not find thing for channel 'tapocontrol:P110:c69109542a:energy#todayEnergyUsage'. Check if you need to set unit metadata.
[main] ERROR org.openhab.core.storage.json.internal.JsonStorage - Couldn't deserialize value 'org.openhab.core.storage.json.internal.StorageEntry@12843fce'. Root cause is: java.lang.IllegalStateException: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.channels[0]
[main] INFO org.openhab.core.tools.internal.Upgrader - Subwoofer_Power: Could not find thing for channel 'tplinksmarthome:hs110:C6A524:power'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Stereoanlage2_TodayRuntime: Could not find thing for channel 'tapocontrol:P110:b305cd4052:54AF977CBAB8:energy#todyRuntime'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Stereoanlage2_TodayUsage: Could not find thing for channel 'tapocontrol:P110:b305cd4052:54AF977CBAB8:energy#todayEnergyUsage'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Kaffeemaschine_Power: Could not find thing for channel 'tplinksmarthome:hs110:C689B4:power'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Synology_Power: Could not find thing for channel 'tapocontrol:P110:c69109542a:energy#actualPower'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Subwoofer_EnergyUsage: Could not find thing for channel 'tplinksmarthome:hs110:C6A524:energyUsage'. Check if you need to set unit metadata.
[main] INFO org.openhab.core.tools.internal.Upgrader - Upgrading JS profile configuration in database '/openhab/userdata/jsondb/org.openhab.core.thing.link.ItemChannelLink.json'
JSON database updated successfully.
SUCCESS: openHAB updated from 3.2.0 to 4.1.0
Contents of the Protokoll display while runing the container (looks good to me)
I exported the protokoll and converted resulting openhab.html to openhab.txt
openhab.txt (21.0 KB)
Contents from docker inspect openhab:
docker_inspect.txt (15.4 KB)
All logs are empty:
What I did already try
- Removed the container and reinstalled it.
- I also tried to add openhab container to the network âbridgeâ as other containers use that also successfully. Then I set the local port 8080 for the container port 8080. No success though
Questions
I already invested hours of investigation and yes I am newbie regarding docker and openhab. I desperately seek help.
- What could I analyse?
- Iâve still no clue where I could inspect logs to see whatâs happening at the webserver level.
