Upgrade HABmin inside openhabian
I’m running openhabian 2.3. The version of HABmin which is installed appears to be 2.0. I see that HABmin version 2.4 is about to be released. Can anyone point me to directions on how to upgrade HABmin in an openhabian install?
Thanks!
Versions:
openhabian is 1.4.1 Releases · openhab/openhabian · GitHub
openHAB2 is 2.3 (stable) or 2.4 (nightly) Releases · openhab/openhab-distro · GitHub
HABmin version should always correspond with openHAB Version, if not installed manually (it’s not recommended to install bundles manually that are available through Paper UI addons).
You are right of course. V2.3 of openHAB2, and 1.4.1 of openhabian.
Thanks for the info on plugin versioning. I’ll wait for an openhabian update. Thanks
