i upgraded from OH3 to OH4. For this upgrade, i have to upgrade the linux basesystem first. I have installed a old openhabian verison, so i upgraded the linux to the newest. After this upgrade, i cannot access the samba shares. I deleted samba complete and installed it via openhabian-config. but without success. i cannot see any errors, but from my desktop pc i cannot reach the raspberry shares. do you have any idea what i can do?
I´m not familiar with Openhabian, so I´d start on linux level.
Start with testparm to check for errors in smb.conf.
Then check locally, if samba shares are visible.
Then in Windows via IP, later via your linux box name
Hey,
thanks for your reply.
Here are the result of checkparam:
Load smb config files from /etc/samba/smb.conf
lpcfg_do_global_parameter: WARNING: The "syslog" option is deprecated
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
# Global parameters
[global]
dns proxy = No
log file = /var/log/samba/log.%m
map to guest = Bad User
max log size = 1000
obey pam restrictions = Yes
pam password change = Yes
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
passwd program = /usr/bin/passwd %u
server role = standalone server
syslog = 0
unix password sync = Yes
wins support = Yes
idmap config * : backend = tdb
[openHAB-addons]
comment = openHAB addons
create mask = 0664
delete veto files = Yes
directory mask = 0775
path = /usr/share/openhab/addons
read only = No
veto files = /Thumbs.db/.DS_Store/._.DS_Store/.apdisk/._*/
[openHAB-conf]
comment = openHAB site configuration
create mask = 0664
path = /etc/openhab
read only = No
[openHAB-userdata]
comment = openHAB userdata
create mask = 0664
path = /var/lib/openhab
read only = No
[openHAB-sys]
comment = openHAB application
create mask = 0664
read only = No
How can i check the samba shares locally? Do you have a commandline expression for me?
Edit:
i try the following:
openhabian@openhab:/var/log/mosquitto $ sudo smbclient --list $(hostname -s)
do_connect: Connection to openhab failed (Error NT_STATUS_CONNECTION_REFUSED)
- Is name server resolving working probably? Looks like “hostname -s” tries to resolve as part of the command. Maybe try at first a command “hostname -s” only to watch for the output and later “smbclient -L localhost” at first to eliminate potential errors here
- Do you have an existing user with access rights? Also watch for /var/log/samba/ log files.
- User rights appropriate for the target directories?
I’d (re-)set the Samba password first. Somewhere in the 1X options I think.
openhabian@openhab:~ $ hostname -s
openhab
openhabian@openhab:~ $ smbclient -L localhost
do_connect: Connection to localhost failed (Error NT_STATUS_CONNECTION_REFUSED)
I have already changed the password, but without access. the folder rights are all correct. i dont have any clue whats going wrong here…
Hmm … new ideas
- smbclient without providing a user name takes the current user “openhab”. Is this user set up for samba?
- Check /etc/resolv.conf
- Check IP being bound to samba. Maybe a wrong interface?
- A firewall issue might apply, if connections to localhost/openhab are not possible
Is your smbd service up and running?
sudo systemctl status smbd.service
openhabian@openhab:~ $ nano /etc/resolv.conf
GNU nano 5.4 /etc/resolv.conf
# Generated by resolvconf
domain fritz.box
nameserver 192.168.178.1
openhabian@openhab:~ $ sudo netstat -plaunt | egrep "ntp|bind|named|samba|?mbd"
tcp 0 0 0.0.0.0:445 0.0.0.0:* LISTEN 13308/smbd
tcp 0 0 0.0.0.0:139 0.0.0.0:* LISTEN 13308/smbd
tcp6 0 0 :::445 :::* LISTEN 13308/smbd
tcp6 0 0 :::139 :::* LISTEN 13308/smbd
openhabian@openhab:~ $ smbclient -L openhab
Enter WORKGROUP\openhabian's password:
Sharename Type Comment
openHAB-addons Disk openHAB addons
openHAB-conf Disk openHAB site configuration
openHAB-userdata Disk openHAB userdata
openHAB-sys Disk openHAB application
IPC$ IPC IPC Service (Samba 4.13.13-Debian)
SMB1 disabled -- no workgroup available
But if i wanted to connect a network drive in windows 11 i see nothing. i try the IP( 192.168.178.134) and the hostname (openhab)
But after a restart of the smbd service, i’m able to login with smdbclient and see the shares… thats a small success…
Edit:
i have added the following to sama.conf
protocol = SMB3
After restarting the service the shares will work! thanks alot!
