- Platform information:
- OS: Windows 10/10.0 (amd64)
- Java Runtime Environment: _11.0.14.1 (Zulu11.54+25-CA)
- openHAB version: openHAB 3.3.0.M5
Hi All
Tried to upgrade from openHAB 3.3.0.M5 to 3.4.0-SNAPSHOT on my Windows 10 machine.
Powershell update.ps1 ran with the following error/warning:
Execute 'POST' instructions for version 3.4.0-SNAPSHOT
Performing post-update tasks for version [3.4.0] :
Could not move C:\openhab\userdata/jsondb/org.openhab.core.transform.TransformationConfiguration.json to C:\openhab\userdata/jsondb/org.openhab.core.transform.Transformation.json
More complete output:
Update Output.txt (3.7 KB)
Checked the folder and see no such file.
On startup of openHAB I get the following:
15:00:03.946 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSMarkatHoylake' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.152 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSEthanatHoylake' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.213 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSAnneatHome' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.217 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'ShellyGateshelly1a4cf12f41d5e10163199231_Input' with pattern 'MAP(doors.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.232 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSRileyatHoylake' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.440 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSRileyatHome' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.534 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSEthanatWilden' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.565 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSAnneatMeadow' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.599 [WARN ] [se.internal.SseItemStatesEventBuilder] - Attempting to send a state update of an item which doesn't exist: ShellyUNIshellyunie8db84d6b3e510163199230_VoltageADC
15:00:04.728 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSEthanatHome' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.754 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSAnneatHoylake' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.931 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSRileyatWilden' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:04.968 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPS_Presence_Home' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:05.017 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'ShellyGarageDoorshelly1a4cf12f486ac10163199232_Input' with pattern 'MAP(doors.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
15:00:05.020 [WARN ] [.rest.core.item.EnrichedItemDTOMapper] - Failed transforming the state 'NULL' on item 'GPSMarkatHome' with pattern 'MAP(presence.map):%s': Couldn't transform value because transformation service of type 'MAP' is not available.
Which I assume are caused by the update error/warning?
Also get the following for my CADDX binding:
15:00:56.133 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.initialize()' on 'org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler@162b5828': For input string: "15.0"
java.lang.NumberFormatException: For input string: "15.0"
at java.lang.NumberFormatException.forInputString(NumberFormatException.java:65) ~[?:?]
at java.lang.Integer.parseInt(Integer.java:652) ~[?:?]
at java.lang.Integer.valueOf(Integer.java:957) ~[?:?]
at java.lang.Integer.decode(Integer.java:1436) ~[?:?]
at org.openhab.binding.caddx.internal.CaddxMessage.<init>(CaddxMessage.java:111) ~[?:?]
at org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler.sendCommand(CaddxBridgeHandler.java:258) ~[?:?]
at org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler.lambda$0(CaddxBridgeHandler.java:165) ~[?:?]
at java.util.concurrent.ConcurrentHashMap.forEach(ConcurrentHashMap.java:1603) ~[?:?]
at org.openhab.binding.caddx.internal.handler.CaddxBridgeHandler.initialize(CaddxBridgeHandler.java:165) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor112.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
15:00:56.483 [ERROR] [.core.thing.internal.ThingManagerImpl] - Exception occurred while initializing handler of thing 'caddx:bridge:e59e4935': For input string: "15.0"
I have reverted back to my 3.3.0.M5
backup after trying the update 3 times.
Any assistance would be greatly appreciated.
Mark
