After upgrade I get the following error in the logfile.
How can I find the root cause?
2024-01-29 20:21:16.484 [ERROR] [st.antlr.ContentAssistContextFactory] - java.lang.RuntimeException: java.lang.NullPointerException
java.util.concurrent.ExecutionException: java.lang.RuntimeException: java.lang.NullPointerException
at java.util.concurrent.FutureTask.report(FutureTask.java:122) ~[?:?]
at java.util.concurrent.FutureTask.get(FutureTask.java:191) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.doCreateContexts(ContentAssistContextFactory.java:181) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.create(ContentAssistContextFactory.java:131) ~[?:?]
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createProposals(ContentAssistService.java:106) ~[?:?]
at org.eclipse.xtext.ide.server.contentassist.ContentAssistService.createCompletionList(ContentAssistService.java:78) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$26(LanguageServerImpl.java:581) ~[?:?]
at org.eclipse.xtext.ide.server.WorkspaceManager.doRead(WorkspaceManager.java:458) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.completion(LanguageServerImpl.java:580) ~[?:?]
at org.eclipse.xtext.ide.server.LanguageServerImpl.lambda$25(LanguageServerImpl.java:566) ~[?:?]
at org.eclipse.xtext.ide.server.concurrent.ReadRequest.lambda$1(ReadRequest.java:66) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:539) [?:?]
Caused by: java.lang.RuntimeException: java.lang.NullPointerException
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:246) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:237) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:232) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:49) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:1) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.BaseContentAssistParser.getFollowElements(BaseContentAssistParser.java:264) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory.handleLastCompleteNodeIsAtEndOfDatatypeNode(ContentAssistContextFactory.java:230) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:161) ~[?:?]
at org.eclipse.xtext.ide.editor.contentassist.antlr.ContentAssistContextFactory$2.call(ContentAssistContextFactory.java:1) ~[?:?]
... 4 more
Caused by: java.lang.NullPointerException
