Upgrade/update from 4.1.2 to 4.2.x problem
Trying to update and upgrade the system from 4.1.2 to latest stable causes problems. The log file tells about problems with reading from server.
How to resolve it?
The following packages will be upgraded:
  base-files bind9-host bind9-libs bsdextrautils bsdutils curl distro-info-data eject fdisk less libblkid1 libc-bin libc-dev-bin libc-devtools libc-l10n libc6 libc6-dbg libc6-dev libcurl3-gnutls
  libcurl4 libfdisk1 libglib2.0-0 libglib2.0-bin libglib2.0-data libgnutls30 libgssapi-krb5-2 libgstreamer-plugins-base1.0-0 libk5crypto3 libkrb5-3 libkrb5support0 libmount1 libpam-systemd
  libsmartcols1 libssh2-1 libsystemd0 libudev1 libuuid1 locales mount nano openhab openhab-addons openjdk-11-jre-headless openjdk-17-jre-headless python3-idna rfkill systemd systemd-sysv
  systemd-timesyncd udev util-linux wpasupplicant
52 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Need to get 663 MB of archives.
After this operation, 46.7 MB of additional disk space will be used.
Get:1 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab all 4.2.1-1 [110 MB]
Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libblkid1 armhf 2.36.1-8+deb11u2 [181 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libuuid1 armhf 2.36.1-8+deb11u2 [82.7 kB]
Get:7 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libfdisk1 armhf 2.36.1-8+deb11u2 [226 kB]
Get:40 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf openjdk-11-jre-headless armhf 11.0.23+9-1~deb11u1 [33.7 MB]
Err:1 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab all 4.2.1-1
  Error reading from server. Remote end closed connection [IP: 34.74.126.177 443]
Get:48 http://archive.raspberrypi.org/debian bullseye/main armhf libc-bin armhf 2.31-13+rpt2+rpi1+deb11u10 [681 kB]
Get:49 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab-addons all 4.2.1-1 [442 MB]
Get:52 http://archive.raspberrypi.org/debian bullseye/main armhf openjdk-17-jre-headless armhf 1:17.0.12+7-2~deb11u1+rpt1 [39.6 MB]
Err:49 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab-addons all 4.2.1-1
26% [40 openjdk-11-jre-headless 24.4 MB/33.7 MB 73%] [52 openjdk-17-jre-headless 7,687 kB/39.6 MB 19%]
It is not unusual for the package servers to be down temporarily for maintainenece. The error says it’s the remote server that is closing the connection so it is likely in some error or maintainenece mode. The error should only persist for a short time.
Thank you. Let me try in couple of days
I made 1 try every day and have the same problem. It stops downloading at the same package
:frowning: any suggestion?
Get:52 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab-addons all 4.2.1-1 [442 MB]
Err:52 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable/main armhf openhab-addons all 4.2.1-1
Fetched 221 MB in 28min 40s (128 kB/s)
E: Failed to fetch https://openhab.jfrog.io/artifactory/openhab-linuxpkg/pool/main/4.2.1/openhab-addons_4.2.1-1_all.deb  Error reading from server. Remote end closed connection [IP: 34.74.126.177 443]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
FAILED
2024-08-15_09:51:00_CEST [openHABian] Checking for default openHABian username:password combination... FAILED
2024-08-15_09:51:02_CEST [openHABian] We hope you got what you came for! See you again soon ;)
It is the addons file causing problems
Quick fix: remove addons from your device
what does it exactly mean? What will be the impact and how to do this?
I am afraid this is not the only one package.
E: Failed to fetch https://openhab.jfrog.io/artifactory/openhab-linuxpkg/pool/main/4.2.1/openhab_4.2.1-1_all.deb  Error reading from server. Remote end closed connection [IP: 34.74.126.177 443]
E: Failed to fetch http://archive.raspberrypi.org/debian/pool/main/o/openjdk-17/openjdk-17-jre-headless_17.0.12%2b7-2%7edeb11u1%2brpt1_armhf.deb  Error reading from server. Remote end closed connection [IP: 2a00:1098:84:1e0::3 80]
FAILED
ok. Then this download error does not only relate to a single file but in general to communication to the server. In this case my workaround will not help.
Even simple update does not work.
Picking up the openhab update i see the following:
[sudo] password for openhabian:
2024-08-19_20:14:39_CEST [openHABian] Checking for root privileges... OK
2024-08-19_20:14:39_CEST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2024-08-19_20:14:39_CEST [openHABian] openHABian configuration tool version: [openHAB]{2024-07-30T20:50:36-06:00}(2dbe780)
2024-08-19_20:14:39_CEST [openHABian] Checking for changes in origin branch openHAB... fatal: unable to access 'https://github.com/openhab/openhabian/': Could not resolve host: github.com
FAILED (fetch origin)
2024-08-19_20:15:14_CEST [openHABian] Updating Linux package information... OK
2024-08-19_20:15:28_CEST [openHABian] Beginning install of latest openhab release (stable repo)... OK
2024-08-19_20:15:32_CEST [openHABian] Adding required keys to apt... OK
2024-08-19_20:15:34_CEST [openHABian] Installing selected openHAB version...
and the installation hangs. Anyone had the same problem?
You’ve got some sort of DNS problem on your network or on that machine. The error is pretty clear:
What ever is supplying DNS to this machine cannot resolve github.com to an IP address.
strange because the ping works:
openhabian@openhabian:~ $ ping github.com
PING github.com (140.82.121.4) 56(84) bytes of data.
64 bytes from lb-140-82-121-4-fra.github.com (140.82.121.4): icmp_seq=1 ttl=42 time=185 ms
64 bytes from lb-140-82-121-4-fra.github.com (140.82.121.4): icmp_seq=2 ttl=41 time=426 ms
64 bytes from lb-140-82-121-4-fra.github.com (140.82.121.4): icmp_seq=3 ttl=41 time=435 ms
^C
and I can access the https://github.com/openhab/openhabian/. So the router is not blocking that at all.
:man_shrugging:
I’m not sure what else could cause a “could not resolve host” error.
