Hi guys,
I’ve openhabian here. I’ve just installed the latest version, and OH is not starting any more. Any suggestion?
thanks
Andrea
2018-09-15 10:12:38.198 [INFO ] [org.eclipse.smarthome.ui.classic ] - FrameworkEvent INFO - org.eclipse.smarthome.ui.classic
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="0.10.0.201809111909"; osgi.identity="org.eclipse.smarthome.ui.classic""
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassPathEntry(ClasspathManager.java:174) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.buildClasspath(ClasspathManager.java:152) ~[?:?]
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.<init>(ClasspathManager.java:81) ~[?:?]
at org.eclipse.osgi.internal.loader.EquinoxClassLoader.<init>(EquinoxClassLoader.java:43) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.createClassLoaderPrivledged(BundleLoader.java:316) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.getModuleClassLoader(BundleLoader.java:233) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findEntries(BundleLoader.java:819) ~[?:?]
at org.eclipse.osgi.container.ModuleWiring.findEntries(ModuleWiring.java:289) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.findResource(ManifestLocalization.java:199) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.lookupResourceBundle(ManifestLocalization.java:130) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.getResourceBundle(ManifestLocalization.java:101) ~[?:?]
at org.eclipse.osgi.storage.ManifestLocalization.getHeaders(ManifestLocalization.java:64) ~[?:?]
at org.eclipse.osgi.storage.BundleInfo$Generation.getHeaders(BundleInfo.java:125) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.privGetHeaders(EquinoxBundle.java:462) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:457) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.getHeaders(EquinoxBundle.java:451) ~[?:?]
at org.apache.aries.spifly.BaseActivator.getAllHeaders(BaseActivator.java:133) ~[?:?]
at org.apache.aries.spifly.BaseActivator.addConsumerWeavingData(BaseActivator.java:95) ~[?:?]
at org.apache.aries.spifly.ConsumerBundleTrackerCustomizer.addingBundle(ConsumerBundleTrackerCustomizer.java:37) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:469) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerAdding(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.java:183) ~[?:?]
at org.osgi.util.tracker.BundleTracker.open(BundleTracker.java:156) ~[?:?]
at org.apache.aries.spifly.BaseActivator.start(BaseActivator.java:79) ~[?:?]
at org.apache.aries.spifly.dynamic.DynamicWeavingActivator.start(DynamicWeavingActivator.java:37) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:779) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:772) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:729) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:933) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309) ~[?:?]
at org.eclipse.osgi.container.Module.doStart(Module.java:581) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:449) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) ~[?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2018-09-15 10:12:38.877 [INFO ] [org.eclipse.smarthome.ui.paper ] - FrameworkEvent INFO - org.eclipse.smarthome.ui.paper
org.osgi.framework.BundleException: The bundle class path entry "patch/" could not be found for the bundle "osgi.identity; type="osgi.bundle"; version:Version="0.10.0.201809111909"; osgi.identity="org.eclipse.smarthome.ui.paper"; singleton:="true""
2018-09-15 10:12:53.312 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Rome'.
2018-09-15 10:12:53.331 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '45.465049,9.094616'.
2018-09-15 10:12:53.363 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'it_IT'.
2018-09-15 10:12:53.369 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Measurement system set to 'SIUnits'.
2018-09-15 10:12:59.910 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 390570f6-06bc-432e-8ece-d7b4650740b6, base URL = http://localhost:8080)
2018-09-15 10:13:26.801 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'outdoor.items'
2018-09-15 10:13:28.007 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'laundry.items'
2018-09-15 10:13:28.164 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'groups.items'
2018-09-15 10:13:28.869 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hobbyroom.items'
2018-09-15 10:13:28.993 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'ifttt.items'
2018-09-15 10:13:29.070 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'kitchen.items'
2018-09-15 10:13:29.667 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'library.items'
2018-09-15 10:13:29.936 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'techroom.items'
2018-09-15 10:13:30.195 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'bathrooms.items'
2018-09-15 10:13:30.640 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'house.items'
2018-09-15 10:13:31.058 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'livingroom.items'
2018-09-15 10:13:31.246 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'presence.items'
2018-09-15 10:13:31.414 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.items'
2018-09-15 10:13:31.694 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'hallways.items'
2018-09-15 10:13:34.887 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist'
2018-09-15 10:13:34.982 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mapdb.persist'
2018-09-15 10:13:35.053 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2018-09-15 10:13:43.913 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-09-15 10:13:51.911 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'mail.rules'
2018-09-15 10:13:58.051 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'visibility.rules'
2018-09-15 10:13:59.762 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'darksky.rules'
2018-09-15 10:14:05.573 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'astro.rules'
2018-09-15 10:14:05.787 [ERROR] [eclipse.smarthome.model.rule.runtime] - bundle org.eclipse.smarthome.model.rule.runtime:0.10.0.201809111909 (135)[org.eclipse.smarthome.model.rule.runtime.internal.RuleRuntimeActivator(185)] : Timeout waiting for reg change to complete unregistered
2018-09-15 10:14:06.224 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
java.lang.IllegalStateException: The service has been unregistered
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:206) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:912) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.unregister(AbstractComponentManager.java:877) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:135) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1053) ~[?:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleStaticCustomizer.addedService(DependencyManager.java:1007) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) ~[?:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
2018-09-15 10:14:08.495 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'thecastle.sitemap'
2018-09-15 10:14:12.112 [ERROR] [ore.thing.internal.ThingRegistryImpl] - Could not inform the ThingTracker 'org.eclipse.smarthome.core.thing.internal.ThingManager@6dc032f8' about the 'THING_ADDED' event!
at org.eclipse.smarthome.core.thing.internal.ThingManager.getThingType(ThingManager.java:553) ~[107:org.eclipse.smarthome.core.thing:0.10.0.201809111909]
at org.eclipse.smarthome.core.thing.internal.ThingManager.initializeHandler(ThingManager.java:653) ~[107:org.eclipse.smarthome.core.thing:0.10.0.201809111909]
at org.eclipse.smarthome.core.thing.internal.ThingManager.registerAndInitializeHandler(ThingManager.java:1046) ~[107:org.eclipse.smarthome.core.thing:0.10.0.201809111909]
at org.eclipse.smarthome.core.thing.internal.ThingManager.thingAdded(ThingManager.java:452) ~[107:org.eclipse.smarthome.core.thing:0.10.0.201809111909]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:211) [107:org.eclipse.smarthome.core.thing:0.10.0.201809111909]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:130) [107:org.eclipse.smarthome.core.thing:0.10.0.201809111909]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1) [107:org.eclipse.smarthome.core.thing:0.10.0.201809111909]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:141) [101:org.eclipse.smarthome.core:0.10.0.201809111909]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.addProvider(AbstractRegistry.java:293) [101:org.eclipse.smarthome.core:0.10.0.201809111909]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:114) [101:org.eclipse.smarthome.core:0.10.0.201809111909]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry$ProviderTracker.addingService(AbstractRegistry.java:1) [101:org.eclipse.smarthome.core:0.10.0.201809111909]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) [?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) [?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) [?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:891) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:877) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:727) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:833) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:775) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:661) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:427) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:339) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:381) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:263) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) [39:org.apache.felix.scr:2.1.2]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) [39:org.apache.felix.scr:2.1.2]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) [?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) [?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) [?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) [?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1634) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1614) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1585) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1528) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
2018-09-15 10:14:14.619 [INFO ] [io.openhabcloud.internal.CloudClient] - Shutting down openHAB Cloud service connection
2018-09-15 10:14:14.706 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 390570f6-06bc-432e-8ece-d7b4650740b6, base URL = http://localhost:8080)
2018-09-15 10:14:15.060 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-hue, openhab-persistence-mapdb, openhab-binding-exec, openhab-binding-nest, openhab-misc-openhabcloud, openhab-binding-network, openhab-persistence-influxdb, openhab-ui-habpanel, openhab-binding-mqtt1, openhab-binding-netatmo, openhab-transformation-map, openhab-ui-classic, openhab-binding-snmp1, openhab-binding-kodi, openhab-binding-logreader, openhab-ui-habmin, openhab-transformation-xslt, openhab-misc-myopenhab, openhab-transformation-exec, openhab-binding-systeminfo, openhab-ui-paper, openhab-binding-wol1, openhab-transformation-scale, openhab-binding-http1, openhab-binding-amazondashbutton, openhab-transformation-javascript, openhab-binding-sonos, openhab-transformation-regex, openhab-binding-openuv, openhab-transformation-jsonpath, openhab-binding-zwave, openhab-transformation-xpath, openhab-action-xbmc, openhab-persistence-rrd4j, openhab-ui-basic, openhab-binding-ntp, openhab-action-mail, openhab-binding-astro, openhab-binding-expire1': Resource has no uri
