I upgraded to 3.2 from 3.1.1 using openhabian-config. The issue I now have is that the UI does not start and it appears not to do anything else anymore either. The log file openhab.log just shows:
2021-12-20 23:30:33.492 [INFO ] [org.openhab.ui.internal.UIService ] - Started UI on port 8080
but going to the page just brings up an empty page, not even a 404 or connection error. Events.log is just completely empty.
Any idea how to fix?
How would I go about downgrading to 3.1.1 again?
I assume you already have tried restarting and clearing the cache ?
With regard to how to downgrade you may have a look at this thread: Downgrade from 3.1.0 to 3.0.1
I actually had not tried to clear the cache. I did it now, but seems not to have helped. I did find some additional information:
openhabian@openhabian:~ $ sudo /bin/systemctl status openhab.service
â—Ź openhab.service - openHAB instance, reachable at http://openhabian:8080
Loaded: loaded (/lib/systemd/system/openhab.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/openhab.service.d
└─override.conf
Active: active (running) since Tue 2021-12-21 17:32:34 CET; 5min ago
Docs: https://www.openhab.org/docs/
https://community.openhab.org
Main PID: 869 (java)
Tasks: 14 (limit: 2178)
CPU: 17.342s
CGroup: /system.slice/openhab.service
└─869 /usr/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/share/openhab -Dopenhab.conf=/etc/openhab -Dopenhab.runtime=/usr/share/openhab/runtime -Dopenhab.userdata=/var/lib/ope>
Dec 21 17:32:53 openhabian karaf[869]: Caused by: java.lang.RuntimeException: Karaf can't startup, make sure the log file can be accessed and written by the user starting Karaf : /var/lib/>
Dec 21 17:32:53 openhabian karaf[869]: at org.apache.karaf.main.lock.SimpleFileLock.<init>(SimpleFileLock.java:55)
Dec 21 17:32:53 openhabian karaf[869]: ... 8 more
Dec 21 17:32:53 openhabian karaf[869]: Caused by: java.io.FileNotFoundException: /var/lib/openhab/tmp/lock (Permission denied)
Dec 21 17:32:53 openhabian karaf[869]: at java.base/java.io.RandomAccessFile.open0(Native Method)
Dec 21 17:32:53 openhabian karaf[869]: at java.base/java.io.RandomAccessFile.open(RandomAccessFile.java:345)
Dec 21 17:32:53 openhabian karaf[869]: at java.base/java.io.RandomAccessFile.<init>(RandomAccessFile.java:259)
Dec 21 17:32:53 openhabian karaf[869]: at java.base/java.io.RandomAccessFile.<init>(RandomAccessFile.java:214)
Dec 21 17:32:53 openhabian karaf[869]: at org.apache.karaf.main.lock.SimpleFileLock.<init>(SimpleFileLock.java:53)
Looks like a file permission issue? I do see that the tmp directory is owned by root, and also the file “lock” in that directory, while all the other directories are owned by openhab (or openhabian):
openhabian@openhabian:/var/lib/openhab $ ls -l
total 68
drwxrwsr-x 2 openhab openhab 4096 Dec 19 18:20 backups
drwxr-xr-x 3 openhab openhab 4096 Dec 21 17:29 cache
drwxrwxr-x 6 openhab openhab 4096 Dec 20 22:49 config
drwxrwxr-x 3 openhab openhab 12288 Dec 20 23:37 etc
-rw-rw-r-- 1 openhab openhab 15517 Dec 14 19:43 hs_err_pid3833.log
drwxrwxr-x 3 openhab openhab 4096 Dec 14 19:43 jsondb
drwxrwxr-x 1 openhab openhabian 4096 Dec 21 17:32 persistence
drwxrwxr-x 2 openhab openhab 4096 Dec 14 19:43 secrets
drwxr-xr-x 4 root root 4096 Dec 21 17:31 tmp
-rw-rw-r-- 1 openhab openhab 36 Dec 14 19:43 uuid
drwxrwxr-x 3 openhab openhab 4096 Dec 18 21:47 zigbee
drwxrwxr-x 2 openhab openhab 4096 Dec 19 16:14 zwave
Should I change the ownership of the directory and files therein? To openhab/openhab?
