I just upgraded my OH2.0 install, done with an early-ish version of the 2.0 Docker image, to the 2.2.0 image that’s currently available on docker.io. I experienced several challenges and thought I’d share them in case someone else travels the same path:
- Missing userdata/etc/version.properties file – my 2.0 image didn’t provide this file, and the new image fails hard if it’s missing. I resolved this by copying the file from the 2.2 image and editing all of the version numbers to make them different to trigger the upgrade process. (If I read the upgrade script correctly, any difference in the file is enough to trigger the upgrade process)
- Stricter syntax checking on sitemaps – my only sitemap file had several syntax issues that the (apparently) more permissive 2.0 parser permitted:
– Group without item= . (changed to Text)
– sendFrequency parameters no longer permitted on Slider (removed)
– Stray entries at bottom of sitemap file (removed) - All items exposed to Alexa (via Hue emulation) were duplicated, causing them to stop working. Solution was to delete the duplicate entries using the Alexa app
- Log files not written (not solved yet)
I haven’t thoroughly checked 2.2 out, but the basics seem to work – control via Alexa and the Android app. I’ll focus on the log issue next.
