I’ve been at this a fair amount today and google isn’t giving me much. The only solutions I’ve found are “Use the online version” which isn’t something I want to do. I’ve tried both 2.0 from git and 2.1 snapshot from cloudbees with the same result.
C:\openhab2>java -version
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) Client VM (build 25.121-b13, mixed mode)
C:\openhab2>start_debug.bat
Launching the openHAB runtime...
karaf.bat: Ignoring predefined value for KARAF_HOME
Listening for transport dt_socket at address: 5005
After that it hangs and does nothing until I kill it. Here is what is in my log:
2017-01-27 15:06:07.761 [ERROR] [org.eclipse.smarthome.core.audio ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.audio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.audio [99]
Unresolved requirement: Import-Package: org.osgi.service.http
at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
2017-01-27 15:06:07.768 [ERROR] [org.eclipse.smarthome.core.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.voice [108]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.audio
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-symbolic-name="org.eclipse.smarthome.core.audio"; bundle-version="0.9.0.b4"; version="0.0.0"
2017-01-27 15:06:07.768 [ERROR] [org.eclipse.smarthome.io.javasound ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.javasound
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.javasound [111]
2017-01-27 15:06:07.772 [ERROR] [org.eclipse.smarthome.io.rest.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.rest.voice [119]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.voice
-> Export-Package: org.eclipse.smarthome.core.voice; bundle-symbolic-name="org.eclipse.smarthome.core.voice"; bundle-version="0.9.0.b4"; version="0.0.0"
2017-01-27 15:06:07.772 [ERROR] [org.eclipse.smarthome.io.webaudio ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.webaudio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.webaudio [121]
2017-01-27 15:06:07.772 [ERROR] [org.eclipse.smarthome.model.core ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.core
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.core [122]
Unresolved requirement: Import-Package: org.eclipse.xtext.common.types.impl
-> Export-Package: org.eclipse.xtext.common.types.impl; bundle-symbolic-name="org.eclipse.xtext.common.types"; bundle-version="2.9.2"; version="0.0.0"; x-internal:="true"
org.eclipse.xtext.common.types [142]
Unresolved requirement: Require-Bundle: org.eclipse.emf.mwe2.lib; bundle-version="2.2.0"; x-installation:="greedy"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.objectweb.asm; bundle-version="[5.0.1,6.0.0)"
2017-01-27 15:06:07.776 [ERROR] [org.eclipse.smarthome.model.rule ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule [127]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.core
-> Export-Package: org.eclipse.smarthome.model.core; bundle-symbolic-name="org.eclipse.smarthome.model.core"; bundle-version="0.9.0.b4"; version="0.0.0"
2017-01-27 15:06:07.780 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule.runtime [128]
2017-01-27 15:06:07.784 [ERROR] [org.eclipse.smarthome.model.script ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script [129]
2017-01-27 15:06:07.784 [ERROR] [lipse.smarthome.model.script.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script.runtime [130]
2017-01-27 15:06:07.788 [ERROR] [org.eclipse.xtext.common.types ] - FrameworkEvent ERROR - org.eclipse.xtext.common.types
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.common.types [142]
2017-01-27 15:06:07.792 [ERROR] [org.eclipse.xtext.xbase ] - FrameworkEvent ERROR - org.eclipse.xtext.xbase
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.xtext.xbase [145]
Unresolved requirement: Import-Package: com.ibm.icu.text; version="4.0.0"; resolution:="optional"
Unresolved requirement: Require-Bundle: org.eclipse.xtext.common.types; visibility:="reexport"
-> Bundle-SymbolicName: org.eclipse.xtext.common.types; bundle-version="2.9.2"; singleton:="true"
2017-01-27 15:06:10.522 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
org.osgi.framework.BundleException: Error while renaming bundle file to final location: C:\OpenHAB\userdata\cache\org.eclipse.osgi\157\0\bundleFile
at org.eclipse.osgi.storage.Storage.getContentFile0(Storage.java:769)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.storage.Storage.getContentFile(Storage.java:745)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.storage.Storage.install(Storage.java:510)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.osgi.internal.framework.BundleContextImpl.installBundle(BundleContextImpl.java:146)[org.eclipse.osgi-3.10.101.v20150820-1432.jar:]
at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundle0(BundleIdBasedRegion.java:117)[8:org.apache.karaf.features.core:4.0.8]
at org.eclipse.equinox.internal.region.BundleIdBasedRegion.installBundleAtLocation(BundleIdBasedRegion.java:97)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.installBundle(FeaturesServiceImpl.java:1261)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:739)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1176)[8:org.apache.karaf.features.core:4.0.8]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl$1.call(FeaturesServiceImpl.java:1074)[8:org.apache.karaf.features.core:4.0.8]
at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_77]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_77]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_77]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_77]
I’ve been using the install docs for windows here: http://docs.openhab.org/installation/windows.html
I added JAVA_HOME = C:\Program Files (x86)\Java\jdk1.8.0_121 in my environment variables. Past that, I’m really not sure what is causing these issues. Has anyone run across and fixed this? I’ve been running 1.8 since it came out with no problems and was trying to update since 2.0 had a release candidate.
