I run openHAB on a small desktop PC running Linux Mint 19.2
This is an apt-get installed openHAB, this is NOT an openHABian install.
This is not a headless system, I have a monitor, keyboard and mouse.
Here is how I upgraded my install to the brand new M1 version
WARNING: “Here be dragons”*
This worked for me but version 4 at this time is NOT officially released! Follow these instruction at your own peril!!! I am just documenting how I did it.
First I checked which version of Java was running on my machine
andy@Treehouse:~$ java -version
openjdk version "11.0.14.1" 2022-02-08
OpenJDK Runtime Environment (build 11.0.14.1+1-Ubuntu-0ubuntu1.18.04)
OpenJDK 64-Bit Server VM (build 11.0.14.1+1-Ubuntu-0ubuntu1.18.04, mixed mode, sharing)
Next I upgrade Java to version 17
andy@Treehouse:~$ sudo apt install openjdk-17-jdk
Next I ran an openHAB backup
andy@Treehouse:~$ sudo openhab-cli backup
Using '/etc/openhab' as conf folder...
Using '/var/lib/openhab' as userdata folder...
Using '/usr/share/openhab/runtime' as runtime folder...
Using '/var/lib/openhab/backups' as backup folder...
Writing to '/var/lib/openhab/backups/openhab-backup-23_03_11-13_53_19.zip'...
Making Temporary Directory if it is not already there
Using /tmp/openhab/backup as TempDir
openHAB backup script
Copying configuration to temporary folder...
Removing unnecessary files...
Zipping folder...
Removing temporary files...
Success! Backup made in /var/lib/openhab/backups/openhab-backup-23_03_11-13_53_19.z
Next I upgraded openHAB
andy@Treehouse:~$ sudo apt-get upgrade openhab
Then I switched versions of Java
step 1
list all the available version of Java which are installed
andy@Treehouse:~$ update-java-alternatives --list
java-1.11.0-openjdk-amd64 1111 /usr/lib/jvm/java-1.11.0-openjdk-amd64
java-1.17.0-openjdk-amd64 1711 /usr/lib/jvm/java-1.17.0-openjdk-amd64
java-1.8.0-openjdk-amd64 1081 /usr/lib/jvm/java-1.8.0-openjdk-amd64
zulu-11-amd64 2115200 /usr/lib/jvm/zulu-11-amd64
step 2
look at the list of versions for version 17. In my list above it is the second line in the list
use the last bit of the line, just the path part
run this comand
andy@Treehouse:~$ sudo update-java-alternatives --set /PATH/GOES/HERE
with the part that says /PATH/GOES/HERE replaced with the path from above
so for example on my machine
andy@Treehouse:~$ sudo update-java-alternatives --set /usr/lib/jvm/java-1.17.0-openjdk-amd64
I then restarted the PC. When the desktop came up, I opened a browser, typed in localhost:8080 and my MainUI interface popped up and looked total normal. I was kind of freaked out because it looked exactly the same. Checked Help & About from the menu and see
openHAB 4.0.0.M1 Milestone Build
Check the logs, have fun ![]()
