- Platform information:
- Hardware: Raspberry Pi 3 Model B Plus Rev 1.3
- OS: Openhabian
- openHAB version: openHAB 3.3.0 - Release Build
- Issue of the topic:
I am running a InfluxDB2 Instance on a webserver and try to push sensor data of two rooms to InfluxDB.
- Temp-Sensor-Livingroom
- Temp-Sensor-Outdoor
Both deliver temperature and humidity values.
Now I want to set up a rule which uploads the latest measurements each hour. I tried to figure out the best way described in multiple blogs and forum posts but I wasnât successfull.
I tried the following approaches:
http-binding
Unfortunately the authentification in the http-binding does not support Tokens which are required from InfluxDB2. Basic Auth is possible according to the InfluxDB Documentation, but it does not seem to work (I cannot even load data with basic auth via POSTMAN but Token based authentifactions works easily) -
Persistence Service
I tried the Persistence Service which seems to work but I do not like to work in config files and the measurement-names and tags which are autogenerated are a bit messy - I prefer to have full control of the tags. Furthermore I like to set up the persistence solution seperately to not mix it up with my sensor measurements and calculations. -
Exec Binding
What seems to work according to multiple forum entries are curl commands with the Exec Binding. I tried to set up the configurations according to Exec - Bindings | openHAB
I like the concept (full control, easy to maintain) but I am struggling to bring it to life.
I have a working curl command which works in the prompt and I tried it with sudo -u openhab <YOUR COMMAND>
, too. These tests were successful.
Next I tried to set up my usecase according to the full example (Exec - Bindings | openHAB) - but within the web-ui.
The curl command would be
curl --request POST "https://MYURL.de/api/v2/write?org=MY_DB&bucket=myBUCKET&precision=s" --header "Authorization: Token xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" --header "Content-Type: text/plain; charset=utf-8" --header "Accept: application/json" --data-binary "test,room=Wohnzimmer temp=20.5,hum=45
As I understood it I need to split it into two parts: the base-part goes into the THING and the Whitelist whereas the dynamic part goes into the .sendCommand
part for the ITEM.
THING:
UID: exec:command:4a6d64e9dc
label: Exec - InfluxDB Data Push
thingTypeUID: exec:command
configuration:
transform: REGEX((.*))
interval: 0
autorun: true
command: 'curl --request POST
application/json" %2$s'
timeout: 15
The string behind command
is copied in the whitelist file as well (without ââ of course).
There is an ITEM linked to the Channel âInputâ of type STRING with the Name ExecInfluxDBDataPush_Eingabewert
I then created a dummy switch and a rule which fires once the dummy switch is pressed (similar to the example)
RULE
configuration: {}
triggers:
- id: "1"
configuration:
itemName: Dummy_Sensorpush_Temp_Hum
command: ON
type: core.ItemCommandTrigger
conditions: []
actions:
- inputs: {}
configuration:
itemName: ExecInfluxDBDataPush_Eingabewert
command: --data-binary "test,room=Wohnzimmer temp=99.5,hum=99"
type: core.ItemCommandAction
This is a first test to see if I can send hardcoded measurement values. Afterwards I am going to set up a proper rule with the real values.
And that is where I am stuck - when I press the button the REST command does not seem to work. I can read a logfile entry:
2023-01-19 16:54:25.878 [INFO ] [openhab.event.ItemCommandEvent ] - Item âExecInfluxDBDataPush_Eingabewertâ received command --data-binary âtest,room=Wohnzimmer temp=99.5,hum=99â
But the InfluxDB does not receive any data.
My Questions are:
- What am I doing wrong? What can I do to debug my issue?
- Is there another binding to easily connect to InfluxDB2?
Best regards
Rey
