This should work:
import java.util.HashMap
val numRooms = 6
val numModules = 1
val Procedures$Procedure3<List, Integer, Integer> processRequest = [ itemQueryList, roomNumber, moduleNumber |
val HashMap<String, String> idMap = newHashMap(
"20" -> "module_id",
"21" -> "cooling_available",
"22" -> "holiday_mode",
"23" -> "forced_eco_mode",
"24" -> "hc_mode",
"25" -> "hc_masterslave",
"26" -> "ts_sv_version",
"27" -> "holiday_setpoint",
"28" -> "average_temp_low",
"29" -> "low_temp_alarm_limit",
"30" -> "low_temp_alarm_hysteresis",
"31" -> "remote_access_alarm",
"32" -> "device_lost_alarm",
"33" -> "no_comm_controller1",
"34" -> "no_comm_controller2",
"35" -> "no_comm_controller3",
"36" -> "no_comm_controller4",
"37" -> "average_room_temperature",
"38" -> "controller_presence",
"39" -> "allow_hc_mode_change",
"40" -> "hc_master_type",
"60" -> "output_module",
"61" -> "rh_deadzone",
"62" -> "controller_sv_version",
"63" -> "thermostat_presence",
"64" -> "supply_high_alarm",
"65" -> "supply_low_alarm",
"66" -> "average_room_temperature_NO",
"67" -> "measured_outdoor_temperature",
"68" -> "supply_temp",
"69" -> "dehumidifier_status",
"70" -> "outdoor_sensor_presence",
"80" -> "eco_profile_active_cf",
"81" -> "dehumidifier_control_activation",
"82" -> "rh_control_activation",
"83" -> "eco_profile_number",
"84" -> "setpoint_write_enable",
"85" -> "cooling_allowed",
"86" -> "rh_setpoint",
"87" -> "min_setpoint",
"88" -> "max_setpoint",
"89" -> "min_floor_temp",
"90" -> "max_floor_temp",
"91" -> "room_setpoint",
"92" -> "eco_offset",
"93" -> "eco_profile_active",
"94" -> "home_away_mode_status",
"95" -> "room_in_demand",
"96" -> "rh_limit_reached",
"97" -> "floor_limit_status",
"98" -> "technical_alarm",
"99" -> "tamper_indication",
"100" -> "rf_alarm",
"101" -> "battery_alarm",
"102" -> "rh_sensor",
"103" -> "thermostat_type",
"104" -> "regulation_mode",
"105" -> "room_temperature",
"106" -> "room_temperature_ext",
"107" -> "rh_value",
"108" -> "ch_linked_to_th",
"109" -> "room_name",
"110" -> "utilization_factor_24h",
"111" -> "utilization_factor_7d",
"112" -> "reg_mode",
"113" -> "channel_average",
"114" -> "radiator_heating")
val url = "http://<ip>/api"
val contenttype = "application/json"
var POSTrequest = '{"jsonrpc":"2.0", "id":8, "method":"read", "params":{ "objects":[%s]}}'
val request = String.format(POSTrequest, itemQueryList.join(','))
val json = sendHttpPostRequest(url, contenttype, request);
val count = Integer::parseInt(transform("JSONPATH", "$.result.objects.length()", json));
for(var i = 0; i < count; i++) {
if (transform("JSONPATH", "$.result.objects[" +i+ "]", json).contains("value")) {
val Number id = Integer::parseInt(transform("JSONPATH", "$.result.objects[" +i+ "].id", json))
val value = transform("JSONPATH", "$.result.objects[" +i+ "].properties.85.value", json)
var Number realId = id - (moduleNumber * 500) - (roomNumber * 40)
val printString = "%1$-35s : %2$10s : %3$2d : %4$2d"
val name = idMap.get("" + realId)
logWarn("Uponor", String.format(printString, name, ""+value, roomNumber.intValue(), moduleNumber.intValue()))
rule "Read Uponor values 2"
Time cron "0 0/1 * * * ?"
val itemQuery = '{"id":"%s","properties":{"85":{}}}'
val itemQueryList = newArrayList()
//Add global keys to query
for (var i = 20; i < 41; i++) {
itemQueryList.add(String.format(itemQuery, i))
logWarn("Uponor", "************ Global values *****************")
processRequest.apply(itemQueryList, 0, 0)
//Add module keys to query
for (var j = 0; j < numModules; j++) {
for (var i = 60; i < 71; i++) {
itemQueryList.add(String.format(itemQuery, i + j*500))
logWarn("Uponor", "************ Module " + j + " values *****************")
processRequest.apply(itemQueryList, 0, j)
//Query room keys
for (var k = 0; k < numRooms; k++) {
for (var i = 80; i < 115; i++) {
itemQueryList.add(String.format(itemQuery, i + k*40 + j*500))
logWarn("Uponor", "************ Room " + k + " and Module " + j + " values *****************")
processRequest.apply(itemQueryList, k, j)
