I have this controller for my floorheating and have found out that the webinterface uses a simple JSON format for returning values like current measured temperature, humidity, setpoint etc. I would be very cool to get these values into OH2, but I simply do not have the skills to develop it ![]()
have found a working Python example which I’ve modified so it matches my system, but going from there into OH2 is beyond me. Is there anyone who would be interested in developing such a binding or maybe know how the data could be imported in OH?
Hi, i am in the same situation and was just about to start develop this, can you send me the python script so i can have a look at it?
I did not manage to get further with this. I did start to find the different settings, by looking at JSON output, but my limited Python skills resulted in my giving up.
If you’re keen on developing a binding I’d be happy to assist. Maybe we can even get Peter Fürle who did the original reverse engineering (The link in the previous post) to assist :).
I also reached out to Uponor, but they were not willing to help, so I guess they wish to stay within their own product-range, and not interface with the rest of the world…
Hi @Fraggler, did you manage to look further into it?
This should be rather simple using the Http binding and the json transform.
I’m waiting for my smatrix system and will give it a go once I have set it up.
Looking forward to see if it’s possible. Unfortunately I don’t have the skills ![]()
I have been bale to read values from my uponor system using a rule that updates the items once per minute.
items:
String Room1Name "Room [%s]"
Number Room1Temp "Temp [%.1f °C]"
sitemap:
Frame label="Uponor" {
Text item=Room1Name
Text item=Room1Temp
rule:
rule "Read Uponor values"
Time cron "0 0/1 * * * ?"
var url = "http://<ip to uponor gateway>/api";
var contenttype = "application/json";
var POSTrequest = '{"jsonrpc":"2.0",
"id":8,
"method":"read",
"params":{
"objects":[
{"id":"105","properties":{"85":{}}},
{"id":"109","properties":{"85":{}}}
var json = sendHttpPostRequest(url, contenttype, POSTrequest);
var count = Integer::parseInt(transform("JSONPATH", "$.result.objects.length()", json));
var i = 0
while (i < count) {
if (transform("JSONPATH", "$.result.objects[" +i+ "].id", json).equals("105")){
Room1Temp.postUpdate(transform("JSONPATH", "$.result.objects[" +i+ "].properties.85.value", json));
if (transform("JSONPATH", "$.result.objects[" +i+ "].id", json).equals("109")){
Room1Name.postUpdate(transform("JSONPATH", "$.result.objects[" +i+ "].properties.85.value", json));
i++;
To add more values you just add one line in the ‘objects’ array:
{"id":"<the id you want here>","properties":{"85":{}}},
and add a new if-statement that checks the id you added and updates the corresponding item.
I have gotten the id mappings from the javascript file but I don’t know what all of then does yet:
System Value mappings:
20 = "module_id"
21 = "cooling_available"
22 = "holiday_mode"
23 = "forced_eco_mode" //Home/Away
24 = "hc_mode"
25 = "hc_masterslave"
26 = "ts_sv_version"
27 = "holiday_setpoint" //Note that the setpoint for the rooms doesn’t change when holiday mode is enabled.
28 = "average_temp_low" //No value?
29 = "low_temp_alarm_limit"
30 = "low_temp_alarm_hysteresis"
31 = "remote_access_alarm" //No value?
32 = "device_lost_alarm" //No value?
33 = "no_comm_controller1"
34 = "no_comm_controller2"
35 = "no_comm_controller3"
36 = "no_comm_controller4"
37 = "average_room_temperature"
38 = "controller_presence"
39 = "allow_hc_mode_change"
40 = "hc_master_type"
Module Value mappings:
(x = module number) 0 for me… What is module? The X165?
x*500 + 60 = "output_module"
x*500 + 61 = "rh_deadzone"
x*500 + 62 = "controller_sv_version"
x*500 + 63 = "thermostat_presence"
x*500 + 64 = "supply_high_alarm"
x*500 + 65 = "supply_low_alarm"
x*500 + 66 = "average_room_temperature_NO"
x*500 + 67 = "measured_outdoor_temperature"
x*500 + 68 = "supply_temp"
x*500 + 69 = "dehumidifier_status"
x*500 + 70 = "outdoor_sensor_presence"
Zone property mappings:
x = module number
y = room number (0-5 for me)
x*500 + y*40 + 80 = "eco_profile_active_cf" //Read only? Seem to be set by home/Away.
x*500 + y*40 + 81 = "dehumidifier_control_activation"
x*500 + y*40 + 82 = "rh_control_activation"
x*500 + y*40 + 83 = "eco_profile_number"
x*500 + y*40 + 84 = "setpoint_write_enable" //Use room thermostat (0) or app (1)
x*500 + y*40 + 85 = "cooling_allowed"
x*500 + y*40 + 86 = "rh_setpoint"
x*500 + y*40 + 87 = "min_setpoint" //Min value on thermostat
x*500 + y*40 + 88 = "max_setpoint" //Max value on thermostat
x*500 + y*40 + 89 = "min_floor_temp"
x*500 + y*40 + 90 = "max_floor_temp"
x*500 + y*40 + 91 = "room_setpoint" //Desired temperature in room
x*500 + y*40 + 92 = "eco_offset" //
x*500 + y*40 + 93 = "eco_profile_active" //Read only? Seem to be set by home/Away.
x*500 + y*40 + 94 = "home_away_mode_status" //Read only? I can’t get this to change at all…
x*500 + y*40 + 95 = "room_in_demand"
x*500 + y*40 + 96 = "rh_limit_reached"
x*500 + y*40 + 97 = "floor_limit_status"
x*500 + y*40 + 98 = "technical_alarm"
x*500 + y*40 + 99 = "tamper_indication"
x*500 + y*40 + 100 = "rf_alarm"
x*500 + y*40 + 101 = "battery_alarm"
x*500 + y*40 + 102 = "rh_sensor"
x*500 + y*40 + 103 = "thermostat_type"
x*500 + y*40 + 104 = "regulation_mode"
x*500 + y*40 + 105 = "room_temperature" //Actual temperature
x*500 + y*40 + 106 = "room_temperature_ext"
x*500 + y*40 + 107 = "rh_value"
x*500 + y*40 + 108 = "ch_linked_to_th"
x*500 + y*40 + 109 = "room_name" // This could be usefull…
x*500 + y*40 + 110 = "utilization_factor_24h"
x*500 + y*40 + 111 = "utilization_factor_7d"
x*500 + y*40 + 112 = "reg_mode"
x*500 + y*40 + 113 = "channel_average"
x*500 + y*40 + 114 = "radiator_heating"
I will get back on how to set values.
It seem that the trends can be fetched by using property 856 instead of 85 for id 37 (Avg. room temp), x500 + y40 + 91 (room set point) and x500 + y40 + 105 (room temperature).
The json result will then be a 24 item long array (I’m guessing one value per hour).
Looks very cool! Will try this next week for sure ![]()
I have made the rule a bit easier to use. Now all you have to do is update the hashmap with the id of the field and the item that should hold the value:
EDIT: Cleaned up the code.
import java.util.HashMap
//Create a map that map from uponor id to the item that should be updated:
val HashMap<String, GenericItem> itemMap = newHashMap(
'105' -> Room0Temp,
'109' -> Room0Name,
'145' -> Room1Temp,
'149' -> Room1Name,
'185' -> Room2Temp,
'189' -> Room2Name,
'225' -> Room3Temp,
'229' -> Room3Name,
'265' -> Room4Temp,
'269' -> Room4Name,
'305' -> Room5Temp,
'309' -> Room5Name
var POSTrequest = '{"jsonrpc":"2.0", "id":8, "method":"read", "params":{ "objects":[%s]}}'
val itemQuery = '{"id":"%s","properties":{"85":{}}}'
val itemQueryList = newArrayList()
val idSet = itemMap.keySet
idSet.forEach[ key | itemQueryList.add(String.format(itemQuery, key)) ]
POSTrequest = String.format(POSTrequest, itemQueryList.join(','))
for(var i = 0; i < count; i++) {
val id = transform("JSONPATH", "$.result.objects[" +i+ "].id", json);
val value = transform("JSONPATH", "$.result.objects[" +i+ "].properties.85.value", json);
val item = itemMap.get(id);
item.postUpdate(value);
Just got home and tried it. Seems to work fine :).
Is there a way of retrieving “everything”, so we can poke around the different values?
As a side note, I took mine apart and found a nice serial interface with login prompt. Didn’t get much further than that. I’d like to see if the FTP server could be disabled / used.
There is no good way to get all values.
I made a rule that can print all values in the list of keys above to the log but you have to map them to the correct key manually.
It will only list key value pairs if the key actually has a value.
There also seem to be a limit on how big queries can be. I tried to add all id:s to one query but that failed so I split it up into multiple queries.
EDIT: Cool about the serial interface. Let me know if you get something usefull out of it. It would be nice to be able to interface it directtly without the U@home gateway.
val numRooms = 6
val numModules = 1
val Procedures$Procedure1 processRequest = [ itemQueryList |
val url = "http://192.168.0.117/api"
val contenttype = "application/json"
val request = String.format(POSTrequest, itemQueryList.join(','))
val json = sendHttpPostRequest(url, contenttype, request);
val count = Integer::parseInt(transform("JSONPATH", "$.result.objects.length()", json));
if (transform("JSONPATH", "$.result.objects[" +i+ "]", json).contains("value")) {
logWarn("Uponor", "id " + id + ": value = " + value)
//Add global keysto query
for (var i = 20; i < 41; i++) {
itemQueryList.add(String.format(itemQuery, i))
//Add module keys to query
for (var j = 0; j < numModules; j++) {
for (var i = 60; i < 71; i++) {
itemQueryList.add(String.format(itemQuery, i + j*500))
processRequest.apply(itemQueryList)
//Query room keys
for (var k = 0; k < numRooms; k++) {
for (var i = 80; i < 115; i++) {
itemQueryList.add(String.format(itemQuery, i + k*40 + j*500))
It’s actually on the U@Home module, so it doesn’t help much. I also discovered that I cannot use U@Home without the display (I-167). If it’s absent, then I don’t get any values via U@Home at all.
Is it possible to do a kind of mapping between keys and descriptions in this ‘print all’ rule, so we get an overview of what’s what?
I’m thinking something in the lines of:
General
Id Description
20 Serial number
23 Home/Away status
26 TS SW version
etc.
Rooms
Id-offset Description
10 Temperature setpoint
24 Current temperature
26 Humidity (%)
28 Room description
29 Utilization (%)
etc.
When the overview is in place, then it’s easier to produce the items & rule.
I also assume that the alarms are there somewhere? Just like the data for the graphs.
This prints out the data in the format:
field name : value : room number : module number
I will see if I can find the alarms.
val numRooms = 6
val numModules = 1
val HashMap<String, String> idMap = newHashMap(
"20" -> "module_id",
"21" -> "cooling_available",
"22" -> "holiday_mode",
"23" -> "forced_eco_mode",
"24" -> "hc_mode",
"25" -> "hc_masterslave",
"26" -> "ts_sv_version",
"27" -> "holiday_setpoint",
"28" -> "average_temp_low",
"29" -> "low_temp_alarm_limit",
"30" -> "low_temp_alarm_hysteresis",
"31" -> "remote_access_alarm",
"32" -> "device_lost_alarm",
"33" -> "no_comm_controller1",
"34" -> "no_comm_controller2",
"35" -> "no_comm_controller3",
"36" -> "no_comm_controller4",
"37" -> "average_room_temperature",
"38" -> "controller_presence",
"39" -> "allow_hc_mode_change",
"40" -> "hc_master_type",
"60" -> "output_module",
"61" -> "rh_deadzone",
"62" -> "controller_sv_version",
"63"-> "thermostat_presence",
"64" -> "supply_high_alarm",
"65" -> "supply_low_alarm",
"66" -> "average_room_temperature_NO",
"67" -> "measured_outdoor_temperature",
"68" -> "supply_temp",
"69" -> "dehumidifier_status",
"70" -> "outdoor_sensor_presence",
"80" -> "eco_profile_active_cf",
"81" -> "dehumidifier_control_activation",
"82" -> "rh_control_activation",
"83" -> "eco_profile_number",
"84" -> "setpoint_write_enable",
"85" -> "cooling_allowed",
"86" -> "rh_setpoint",
"87" -> "min_setpoint",
"88" -> "max_setpoint",
"89" -> "min_floor_temp",
"90" -> "max_floor_temp",
"91" -> "room_setpoint",
"92" -> "eco_offset",
"93" -> "eco_profile_active",
"94" -> "home_away_mode_status",
"95" -> "room_in_demand",
"96" -> "rh_limit_reached",
"97" -> "floor_limit_status",
"98" -> "technical_alarm",
"99" -> "tamper_indication",
"100" -> "rf_alarm",
"101" -> "battery_alarm",
"102" -> "rh_sensor",
"103" -> "thermostat_type",
"104" -> "regulation_mode",
"105" -> "room_temperature",
"106" -> "room_temperature_ext",
"107" -> "rh_value",
"108" -> "ch_linked_to_th",
"109" -> "room_name",
"110" -> "utilization_factor_24h",
"111" -> "utilization_factor_7d",
"112" -> "reg_mode",
"113" -> "channel_average",
"114" -> "radiator_heating")
val url = "http://<ip to uponor gateway>/api"
val Number id = Integer::parseInt(transform("JSONPATH", "$.result.objects[" +i+ "].id", json))
val Number module = id/500
var tmp = id.intValue() % 500;
if ((tmp - 80) >= 0) {
val Number room = (tmp - 80)/40
val Number realId = (tmp % 40) + 80
val printString = "%1$-35s : %2$10s : %3$2d : %4$2d"
val name = idMap.get("" + realId)
logWarn("Uponor", String.format(printString, name, ""+value, room.intValue(), module.intValue()))
else {
val printString = "%1$-35s : %2$10s : -- : %3$2d"
val name = idMap.get("" + tmp)
logWarn("Uponor", String.format(printString, name, ""+value, module.intValue()))
rule "Read Uponor values 2"
//Query room keys
Found it.
This rule will write the active alarms in the log.
EDIT: This reads all active alarms. They can also be read like the other values if you change the standard property “85” to “77” for the name and “662” for the state.
example:
2018-08-01 22:13:00.140 [WARN ] [clipse.smarthome.model.script.Uponor] - Average temp low_u0_z0_cmd0 (id = 28) with state true
rule "Read Uponor alarms"
val url = "http://<ip>/api";
val contenttype = "application/json";
var POSTrequest = '{"jsonrpc":"2.0","id":2,"method":"readactivealarms","params":{}}'
val json = sendHttpPostRequest(url, contenttype, POSTrequest);
val alarm = transform("JSONPATH", "$.result.objects[" +i+ "].properties.77.value", json)
val state = transform("JSONPATH", "$.result.objects[" +i+ "].properties.662.value", json)
if (transform("JSONPATH", "$.result.objects[" +i+ "].id", json).contains("663")) {
val acced = transform("JSONPATH", "$.result.objects[" +i+ "].properties.663.value", json)
logWarn("Uponor", alarm + " (id = " + id + ") with state " + (state!=0) + " and acced " + (acced!=0))
else {
logWarn("Uponor", alarm + " (id = " + id + ") with state " + (state!=0))
I made a new rule to read the alarms regardless if they have triggered. That is most likely more useful.
It only reads the state and assumes that the item is a switch but that should be easy to change if you want to.
As you can see it is almost identical to the other one. So if you find other property values that makes sense it should be easy to create new rules for those.
val HashMap<String, GenericItem> alarmItemMap = newHashMap(
'28' -> TempAlarm
val itemQuery = '{"id":"%s","properties":{"77":{}, "662":{}}}'
val idSet = alarmItemMap.keySet
val item = alarmItemMap.get(id);
if (state.equals("0") {
item.postUpdate('OFF')
else {
item.postUpdate('ON')
You are indeed insane
. Really admire your skills in finding these things. Will test tomorrow, thanks for your work so far!
I’ve tried this, and it’s nice to get an overview of the different data. I have 12 zones, but the last two gives other results than the first 10 (have added separation lines for the output):
2018-08-02 08:42:01.440 [WARN ] [clipse.smarthome.model.script.Uponor] - ****** Room: 9
2018-08-02 08:42:01.564 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_profile_active_cf : 0 : 9 : 0
2018-08-02 08:42:01.565 [WARN ] [clipse.smarthome.model.script.Uponor] - dehumidifier_control_activation : 0 : 9 : 0
2018-08-02 08:42:01.566 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_control_activation : 0 : 9 : 0
2018-08-02 08:42:01.566 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_profile_number : 0.0 : 9 : 0
2018-08-02 08:42:01.567 [WARN ] [clipse.smarthome.model.script.Uponor] - setpoint_write_enable : 0 : 9 : 0
2018-08-02 08:42:01.568 [WARN ] [clipse.smarthome.model.script.Uponor] - cooling_allowed : 1 : 9 : 0
2018-08-02 08:42:01.568 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_setpoint : 100.0 : 9 : 0
2018-08-02 08:42:01.569 [WARN ] [clipse.smarthome.model.script.Uponor] - min_setpoint : 5.0 : 9 : 0
2018-08-02 08:42:01.570 [WARN ] [clipse.smarthome.model.script.Uponor] - max_setpoint : 35.0 : 9 : 0
2018-08-02 08:42:01.571 [WARN ] [clipse.smarthome.model.script.Uponor] - min_floor_temp : 20.0 : 9 : 0
2018-08-02 08:42:01.571 [WARN ] [clipse.smarthome.model.script.Uponor] - max_floor_temp : 26.0 : 9 : 0
2018-08-02 08:42:01.572 [WARN ] [clipse.smarthome.model.script.Uponor] - room_setpoint : 22.1 : 9 : 0
2018-08-02 08:42:01.573 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_offset : 4.0 : 9 : 0
2018-08-02 08:42:01.573 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_profile_active : 0 : 9 : 0
2018-08-02 08:42:01.573 [WARN ] [clipse.smarthome.model.script.Uponor] - home_away_mode_status : 0 : 9 : 0
2018-08-02 08:42:01.574 [WARN ] [clipse.smarthome.model.script.Uponor] - room_in_demand : 0 : 9 : 0
2018-08-02 08:42:01.575 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_limit_reached : 0 : 9 : 0
2018-08-02 08:42:01.575 [WARN ] [clipse.smarthome.model.script.Uponor] - floor_limit_status : 0 : 9 : 0
2018-08-02 08:42:01.577 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_sensor : 1 : 9 : 0
2018-08-02 08:42:01.578 [WARN ] [clipse.smarthome.model.script.Uponor] - thermostat_type : 2.0 : 9 : 0
2018-08-02 08:42:01.578 [WARN ] [clipse.smarthome.model.script.Uponor] - regulation_mode : 0.0 : 9 : 0
2018-08-02 08:42:01.579 [WARN ] [clipse.smarthome.model.script.Uponor] - room_temperature : 25.3 : 9 : 0
2018-08-02 08:42:01.580 [WARN ] [clipse.smarthome.model.script.Uponor] - room_temperature_ext : 1802.6 : 9 : 0
2018-08-02 08:42:01.581 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_value : 51.0 : 9 : 0
2018-08-02 08:42:01.581 [WARN ] [clipse.smarthome.model.script.Uponor] - ch_linked_to_th : 512.0 : 9 : 0
2018-08-02 08:42:01.582 [WARN ] [clipse.smarthome.model.script.Uponor] - room_name : 10 Kids1 : 9 : 0
2018-08-02 08:42:01.583 [WARN ] [clipse.smarthome.model.script.Uponor] - utilization_factor_24h : 0.0 : 9 : 0
2018-08-02 08:42:01.583 [WARN ] [clipse.smarthome.model.script.Uponor] - utilization_factor_7d : 0.0 : 9 : 0
2018-08-02 08:42:01.584 [WARN ] [clipse.smarthome.model.script.Uponor] - reg_mode : 0 : 9 : 0
2018-08-02 08:42:01.585 [WARN ] [clipse.smarthome.model.script.Uponor] - channel_average : 1 : 9 : 0
2018-08-02 08:42:01.586 [WARN ] [clipse.smarthome.model.script.Uponor] - radiator_heating : 0.0 : 9 : 0
2018-08-02 08:42:01.591 [WARN ] [clipse.smarthome.model.script.Uponor] -
2018-08-02 08:42:01.591 [WARN ] [clipse.smarthome.model.script.Uponor] - ****** Room: 10
2018-08-02 08:42:01.666 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_profile_active_cf : 0 : 10 : 0
2018-08-02 08:42:01.667 [WARN ] [clipse.smarthome.model.script.Uponor] - dehumidifier_control_activation : 0 : 10 : 0
2018-08-02 08:42:01.668 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_control_activation : 0 : 10 : 0
2018-08-02 08:42:01.668 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_profile_number : 0.0 : 10 : 0
2018-08-02 08:42:01.669 [WARN ] [clipse.smarthome.model.script.Uponor] - setpoint_write_enable : 0 : 10 : 0
2018-08-02 08:42:01.670 [WARN ] [clipse.smarthome.model.script.Uponor] - cooling_allowed : 1 : 10 : 0
2018-08-02 08:42:01.671 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_setpoint : 100.0 : 10 : 0
2018-08-02 08:42:01.671 [WARN ] [clipse.smarthome.model.script.Uponor] - min_setpoint : 5.0 : 10 : 0
2018-08-02 08:42:01.672 [WARN ] [clipse.smarthome.model.script.Uponor] - max_setpoint : 35.0 : 10 : 0
2018-08-02 08:42:01.673 [WARN ] [clipse.smarthome.model.script.Uponor] - min_floor_temp : 20.0 : 10 : 0
2018-08-02 08:42:01.674 [WARN ] [clipse.smarthome.model.script.Uponor] - max_floor_temp : 26.0 : 10 : 0
2018-08-02 08:42:01.674 [WARN ] [clipse.smarthome.model.script.Uponor] - room_setpoint : 18.6 : 10 : 0
2018-08-02 08:42:01.675 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_offset : 4.0 : 10 : 0
2018-08-02 08:42:01.676 [WARN ] [clipse.smarthome.model.script.Uponor] - eco_profile_active : 0 : 10 : 0
2018-08-02 08:42:01.677 [WARN ] [clipse.smarthome.model.script.Uponor] - home_away_mode_status : 0 : 10 : 0
2018-08-02 08:42:01.677 [WARN ] [clipse.smarthome.model.script.Uponor] - room_in_demand : 0 : 10 : 0
2018-08-02 08:42:01.678 [WARN ] [clipse.smarthome.model.script.Uponor] - rh_limit_reached : 0 : 10 : 0
2018-08-02 08:42:01.679 [WARN ] [clipse.smarthome.model.script.Uponor] - floor_limit_status : 0 : 10 : 0
2018-08-02 08:42:01.680 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 1 : -- : 1
2018-08-02 08:42:01.681 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 2.0 : -- : 1
2018-08-02 08:42:01.681 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0.0 : -- : 1
2018-08-02 08:42:01.682 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 25.9 : -- : 1
2018-08-02 08:42:01.683 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 1802.6 : -- : 1
2018-08-02 08:42:01.683 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 50.0 : -- : 1
2018-08-02 08:42:01.684 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 1024.0 : -- : 1
2018-08-02 08:42:01.685 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 11 Kids2 : -- : 1
2018-08-02 08:42:01.685 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0.0 : -- : 1
2018-08-02 08:42:01.686 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0.0 : -- : 1
2018-08-02 08:42:01.687 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0 : -- : 1
2018-08-02 08:42:01.687 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 1 : -- : 1
2018-08-02 08:42:01.688 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0.0 : -- : 1
2018-08-02 08:42:01.693 [WARN ] [clipse.smarthome.model.script.Uponor] -
2018-08-02 08:42:01.694 [WARN ] [clipse.smarthome.model.script.Uponor] - ****** Room: 11
2018-08-02 08:42:01.755 [WARN ] [clipse.smarthome.model.script.Uponor] - module_id : 0 : -- : 1
2018-08-02 08:42:01.756 [WARN ] [clipse.smarthome.model.script.Uponor] - cooling_available : 0 : -- : 1
2018-08-02 08:42:01.757 [WARN ] [clipse.smarthome.model.script.Uponor] - holiday_mode : 0 : -- : 1
2018-08-02 08:42:01.757 [WARN ] [clipse.smarthome.model.script.Uponor] - forced_eco_mode : 0.0 : -- : 1
2018-08-02 08:42:01.758 [WARN ] [clipse.smarthome.model.script.Uponor] - hc_mode : 0 : -- : 1
2018-08-02 08:42:01.758 [WARN ] [clipse.smarthome.model.script.Uponor] - hc_masterslave : 1 : -- : 1
2018-08-02 08:42:01.759 [WARN ] [clipse.smarthome.model.script.Uponor] - ts_sv_version : 100.0 : -- : 1
2018-08-02 08:42:01.760 [WARN ] [clipse.smarthome.model.script.Uponor] - holiday_setpoint : 5.0 : -- : 1
2018-08-02 08:42:01.760 [WARN ] [clipse.smarthome.model.script.Uponor] - average_temp_low : 35.0 : -- : 1
2018-08-02 08:42:01.761 [WARN ] [clipse.smarthome.model.script.Uponor] - low_temp_alarm_limit : 20.0 : -- : 1
2018-08-02 08:42:01.762 [WARN ] [clipse.smarthome.model.script.Uponor] - low_temp_alarm_hysteresis : 26.0 : -- : 1
2018-08-02 08:42:01.762 [WARN ] [clipse.smarthome.model.script.Uponor] - remote_access_alarm : 20.1 : -- : 1
2018-08-02 08:42:01.763 [WARN ] [clipse.smarthome.model.script.Uponor] - device_lost_alarm : 4.0 : -- : 1
2018-08-02 08:42:01.764 [WARN ] [clipse.smarthome.model.script.Uponor] - no_comm_controller1 : 0 : -- : 1
2018-08-02 08:42:01.764 [WARN ] [clipse.smarthome.model.script.Uponor] - no_comm_controller2 : 0 : -- : 1
2018-08-02 08:42:01.765 [WARN ] [clipse.smarthome.model.script.Uponor] - no_comm_controller3 : 0 : -- : 1
2018-08-02 08:42:01.766 [WARN ] [clipse.smarthome.model.script.Uponor] - no_comm_controller4 : 0 : -- : 1
2018-08-02 08:42:01.766 [WARN ] [clipse.smarthome.model.script.Uponor] - average_room_temperature : 0 : -- : 1
2018-08-02 08:42:01.767 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 1 : -- : 1
2018-08-02 08:42:01.768 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 2.0 : -- : 1
2018-08-02 08:42:01.769 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0.0 : -- : 1
2018-08-02 08:42:01.769 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 20.7 : -- : 1
2018-08-02 08:42:01.770 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 1802.6 : -- : 1
2018-08-02 08:42:01.771 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 65.0 : -- : 1
2018-08-02 08:42:01.771 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 2048.0 : -- : 1
2018-08-02 08:42:01.772 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 12 Bath : -- : 1
2018-08-02 08:42:01.773 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0.0 : -- : 1
2018-08-02 08:42:01.774 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0 : -- : 1
2018-08-02 08:42:01.774 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 1 : -- : 1
2018-08-02 08:42:01.775 [WARN ] [clipse.smarthome.model.script.Uponor] - null : 0.0 : -- : 1
Any idea why? For the last room, I can see e.g. ‘device_lost_alarm’, but not for the other 11 rooms.
