USB and restart
Hi
Every time I restart my pi, my USB devices having trouble connecting to the OH again.
It looks like they are getting a new port number.
Is there a way to fix the port number to the devices,
I have a Rfxcom RF433 and a Z-wave usb device
Hi
I dont get what I need to do​:disappointed_face:
Follow the instructions at the link:
The solution I’m trying to implement is based on new udev rule, like the how-to below:
http://hintshop.ludvig.co.nz/show/persistent-names-usb-serial-devices/
and then
just adding the correct arg in openhab script:
-Dgnu.io.rxtx.SerialPorts=/dev/zwavecontroller
in the “JAVA_ARGS_DEFAULT” section.
Hi
Where do I put this
Where is the openHAB script?
in /etc/default/openhab2
Here’s another tutorial:
Hi
If I create the rule /etc/udev/rules.d/99-usb-serial.rule
reboot
and run the ls /dev/tty* command, my symlink does not show up
I have tryed both solutions with no luck.
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", ATTRS{serial}=="A1R3ODL", SYMLINK+="ttyUSB-rfxcom"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="6001", SYMLINK+="ttyUSB-rfxcom", GROUP="dialout", MODE="0660"
Either you reboot or
udevadm control --reload-rules && udevadm trigger
Also make sure your query matches to the dot
